Question about Car Audio & Video
I have 2 pioneer ts-w307d4 400watts rms and an GMD7400M 400 Watt Mono Digital Amplifie now how do i connect this or what is the best connection or setup?
    Scholar:
  • 60 Answers
Liquid_icon:
Since the the subs are 4ohms & the amp's highest output is @ a 2 ohm load, you will need to wire the subs in parallel to the amp. When speakers are wired in parallel it reduces the resistance the amp feels on it's output. In "parallel" means connecting the + terminals of each speaker to the + terminal of the amp. Then connect the - terminals of each speaker to the - terminal of the amp. Make sure you use the correct wire size called for the spk mfg. That's it. If you need additional help, let me know.
peace-out
Posted on Feb 09, 2009
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
What would be the best amp for the money to push 4 pioneer 6.5 i door spea kers n in my truck? they are pioneer ts-a1674r. 6.5 '..3-way 300W max and 35W nominal.
i would get me a 400 watt pioneer amp that ran the same ohms as my speakers maybe a 500 watt to much power on 6.5 will pop them dont ever goby max power its to much for them
Mar 04, 2013 | Jl Audio 13W7 Car Subwoofer
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
I have just brought a GMD8400M PIONEER MONO BLOCK CAN YOU SEND ME THE DIAGRAMES ON HOW TO INSTALL IT.
http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/GM-D8400M_OwnersManual1128.pdf
thats the link to the owners manual enjoy.
if you ever want to upgrade to a higher quality amp let me know, for about 300$ i could have gotten you into a 2000 watt RMS mono block class d that is competion grade.
for a 600 watt like what you have i coulda gotten you into it for about 210 - 225
and for the same amp that you bought i coulda done for about 200
pioneer decks are really nice but the amps are only low to middle end grade.
Sep 17, 2008 | Car Audio & Video
Car Audio & Video Logo
137 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
