Question about Dell Inspiron E1705 Notebook
My ac adapter is not charging my laptop
The light indicator on my ac adapter is not turning green and i hear some sounds while the ac adapter is plugged in, i am afraid to plug it to my laptop coz it sounds like it's going to blow
    President:
  • 1,990 Answers
You have a Bad AC Adapter. If you will replace this it should fix this Problem. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
Why won't my computer boot up?
does not sound easy . Try holding power button in for 30 seconds and then try normal power up. Is the AC adapter plugged into laptop it may have a flat battery. If the Ac to DC adapter is failing to charge the battery this could cause a flat laptop battery and cause the symptoms you are experiencing.
Sep 17, 2015 | ASUS X200 Black 11.6" Notebook 1.5 GHz...
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
Allow one minute for the computer to initialize its components before checking for signs of power.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
No. Go to step 7.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
Yes. Go to step 9.
No. Go to step 7.
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
10. If a spare battery is available, fully charge it, and then install it in the computer.
Yes. Your original battery is defective. get a new battery replacement.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Dell Inspiron E1705 Notebook Logo
65 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
