Question about Acer Aspire One Netbook 8.9" Notebook
Can't boot my Acer Aspire One
My brand-new Aspire One powers on just fine. I get the initial Acer screen, and then a black screen with the following text:
Intel UNDI, PXE-2.1 (build 002)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.09 (080602)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
No bootable device--insert boot disk and press any key
What exactly does this mean? WHAT boot disk? I've tried every "solution" I can find online. The user manual is absolutely useless. Can anyone help???
  • 3 more comments
  • go20 Feb 07, 2009
    I don't have any external devices connected at all. How do you start from "safe mode"? I'm not familiar with that terminology.
    Thanks!
  • go20 Feb 07, 2009
    There is no "recovery disk" and the netbook was supposed to come preinstalled with XP. It's even labeled as such on the keyboard.
    I'm fairly frustrated right now.
  • go20 Feb 07, 2009
    It also has that nifty little Microsoft label on the bottom of the unit that says Windows XP Home Edition ULCPC Acer Incorporated. Wouldn't that indicate that it should have everything it needs? What kind of disk would I use anyway, as there's no CD drive--only the little SD drives.
  • RON LAFLAMME Feb 07, 2009
    The only way you can do this,is
    is try to recover the drive.
  • Anonymous Mar 25, 2014
    acer aspire 5741 black screen No bootable device--insert boot disk. don,t have a disc ?
    President:
  • 2,992 Answers
"Booting" is the process of starting up the computer's operating system (Windows). Settings in the mainboard memory (the BIOS) give the order in which devices are searched for the operating system. The usual order is hard drive first, then the CD drive, and finally over a network.
That clear-as-mud message means the mainboard tried to boot over a network connection and it didn't work. It's telling you to check your network cable or to put in a CD it can boot from.
There are two reasons this is happening. Either the system's BIOS settings have "network" as the first boot device, or (more likely) the operating system wasn't found on the hard drive and the BIOS went looking for a network connection. If the computer used to boot normally and you didn't change the BIOS settings, then something has happened to the hard drive to make it unbootable.
You can check the BIOS settings by pressing the "DELETE" key when you turn the computer on and the Acer logo screen appears. This starts the BIOS setup mode. If the boot order is correct with network boot as the last choice, there is a hardware cause. You might have picked up a virus or worm which has corrupted the disk. The hard drive or the mainboard may have gone bad.
If you have a recovery CD or DVD set, you can try restoring your system. You say it's brand-new, so you might try taking the computer back to the retailer to see if their technical support people can help. Or you can contact Acer to set up service for the computer.
Hope this helps you understand what's happening and that you get the trouble straightened out quickly!
Posted on Feb 07, 2009
    Problem Solver:
  • 9 Answers
HI,
SINCE THIS A NEW COMPUTER TRY RECOVERING THE OS BOOT FILE WITH THE RECOVERY DISK THAT SHOULD HAVE CAME
WITH YOUR LAPTOP. RECOVERY WILL FORMAT
AND RELOAD OS PROGRAMS DRIVERS ALSO
MAKE SURE YOU HAVE YOUR BOOT CONFIGURATION CORRECT BY GOING TO BIOS SOMETIMES F10 KEY ONCE YOU HAVE
BIOS UP JUST SET FOR FACTORY DEFALT SETTINGS RONS_ELCTRO
    THIS IS THE RIGHT WAY TO GO
    Scholar:
  • 127 Answers
You are seeing this message because you dont have an operating system (OS) installed. (or not hardisk at all)
your laptop might not have a preinstalled windows in it. If you have the windows cd you can install it by your self or ask someone that can do it for you.
here are intruction on installing windows OS for XP and vista. you can also install other OS if you want.
for XP installation
for vista installation
let us know if you need more info. please rate
  • 1 more comment
  • James Louie Puro
    James Louie Puro Feb 07, 2009
    just in case, go to the BIOS setup,
    & change the disk controller setting from AHCI to IDE. might worth
    the try.
  • James Louie Puro
    Then that only means that the laptop does not recognizing your hardisk, try my suggestion above or try to boot your laptop while tapping the F12 key repeatedly.
    when you see the bootup menu...select hardisk device.
  • James Louie Puro
    im sorry if your seeing my comments and solutions as inappropriate. we are trying our best to help you and other users. Thanks for the rating and sorry again...good luck.
    Sergeant:
  • 183 Answers
I am assuming that, you got connected some external devices (ex. pendrive, ipod etc) on your laptop so if this is the case then remove your all devices from laptop and reboot back.
if this is not case then try to start from safe mode.
post back if anything changes.
Good luck
Acer aspire 5515(laptop) screen is black turns on screen stayscompletly black...no acer logo nothing just a black screen. power button comes up green u can hear the fan and harddrive start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
On boot up of a acer 3050 i get a black screen of death making me believe its a hard drive problem so i change the harddrive and i still get a black screen of death .it showed me the acer screen then it...
i had a similar problem with my acer aspire 4315 (witch i got for free because of this problem :D ) and i just reinstalled vista then it worked just fine
Dec 23, 2009 | Acer Aspire 3050 Notebook
My acer aspire 5520-5334 won't start
Pull The Battery... Unplug The AC Adapter....
Press and Hold The Power On Button For 30 Seconds...
Reinsert The Battery, Plug In Ac Adapter... Attempt to Power On..
Also Try Removing The Battery And Powering Up Using The Power Cord Alone.....
If Still No Power.... Remove and Reseat The Memory Modules...
Still No?
You'll Next Need To Check To See If The DC Jack Is Faulty...
If It's Faulty, You'll Need To Desolder It, Clean The Board, Resolder a New One ON....
Check The Heatsink/Fan Assembly...it might be clogged...
Still No?
Possibly Faulty Video / GPU Chip....Or a Shorted Out Motherboard..
Dec 01, 2009 | Acer Computers & Internet
Aspire One won't boot
You need to get you a restoring disk...or brand new drive
May 24, 2009 | Acer Aspire One PC Notebook
Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
May 07, 2009 | Acer Aspire One PC Notebook
Just bought acer aspire one laptop model zg5 and will not boot
If it is brand new, I would suggest taking it back to whomever you bought it from and have them replace it or figure out the problem. Should still be under warranty.
Hope this helps and have agoodone!
Ron
Dec 14, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
2,038 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
