Acer monitor will not let me adjust screen position
Im running an acer al2216w through a nvidia geforce 8800gt.for some reason the monitor will not let me manually adjust the clock/focus or the screen shows up under the ocd but the boxes are blanked out and will not let me select them.i also cannot adjust screen position on the acer with the nvidia control panel.the focus thing would be nice to play with but adjusting screen position is most important as i have one of those "little white lines" at the bottom of the screen.i have looked but found nothing specifically addressing the issue.any tips or advice,other than "you should not downgrade your video cards display" is sure one or the other is canceling out the other.hope i put this post in the right section.thanks
  • tvlreject Feb 07, 2009
    ok,you got me to look at the manual and i see it can only
    adjust those settings in "analog mode".what a choice to make dvi
    connection or the ability to adjust the screen.i think ill hook the
    analog up adjust it,switch back to dvi and see if it maintains.any
    other suggestions on alternatives to adjust screen position?thanks
    Problem Solver:
  • 9 Answers
Posted on Feb 07, 2009
Acer Aspire M5641 has a black screen, Power fan is on, CPU fan is on, hard drive has several initial clicking sounds but motor is not running; and i replace a new cmos-bios battery. But nothing...
if by pushing on the power button the machine does not immediately shut down, and you have to hold it down for 5 or 10 seconds, this would indicate that the system is fully functional. the problem would be , your monitor or integrated graphics (NVIDIA GeForce 7100 / nForce 630i) are bad. the graphics can be resolved by adding a graphics card to your system for a reasonable price that varies from 25.00 to 85.00 dollars. the proper card would be a PCI Express video graphics card. here is a link that will provide you with many different options suitable to your need. i suggest you take into consideration if you are a gamer , that you aquire one equal too or greater than 512 self supported ram. 512 will by far exceed the factory video capabilities, enabling a much higher quality video resolution and clearer video /gaming viewing.
Jan 19, 2011 | Acer Aspire M5641 PC Desktop
I have an EVGA 6200 in an HP is working properly, and I can run dual monitors..BUT, my #1 monitor is a 23" Acer LCD, and my #2 is a 19" Dynex TV. #1 is run of the VGA cable, and #2 is run off the...
you have an nvidia based card. there should be nvidia control panel with those drivers, if not download it. to find out just right click an empty portion of your desktop. then look for nvidia control panel. if it is there just start it. then on the left side of the control panel look for display and click the subcategory set up multiple displays. this will give you a window that shows both of your displays. just uncheck the clone displays. this will allow you to configure them independently.
Jun 26, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Which gpu is better?
The video card is a joke, strictly for office use. Get a GTS 250 , it's an very upgraded form of 9600GT. 8800GT is far too old and weak for newer games.
Mar 03, 2010 | Intel DG31PR Motherboard
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
When i boot the screen colour goes off
Try it with another monitor if possible and see if the colour gets messed up with that screen as well. If you cannot try that, visit
And get the correct and newest drivers for your 8800GT. Select the right operating system and install them. It should work. If not, let me know!
Jan 12, 2009 | PNY XLR8 GeForce 8800GT 512MB PCI Express...
GeForce 8800gt, will not play videos without pixelizing
Try updating the drivers for the 8800gt, if that doesnt work, try installing a codec pack (just google)
Dec 30, 2008 | Computers & Internet
Palit Geforce 8800gt 1Gig Glitches + BSOD
Nvidia's recommendations for the 8800GT are 26 Amps (I think) on the 12V rail... Although you would think 20 Amps would be enough, my next step would be to uninstall the video card driver again, get yourself a copy of a program called Driver Cleaner dot net, run the program in safe mode to completely remove all of the Nvidia driver, then reboot into Windows, download the latest WHQL driver for your card from nvidia's website, and see if that fixes it. If not, either try the card in a system with a more powerful power supply, or get a more powerful power supply, and see if your error goes away.
Dec 24, 2008 | Palit Microsystems GeForce 8800 GT,, PCI...
8800gt black screen
Hi Juan016, you have done everything right. I'd say the 8800GT is bad & return it for a refund. Run the 8600GT & the NVIDIA 6100 at the same time. If you check the middle of page 9 in your manual. NOTE: It states; if a PCI-E is inserted the bios will automatically run the PCI-E card. (No need to make a bios setting change).
It also says if you change the setting in the bios to, OnChip and PCIe VGA, the motherboard should run both. Depending what amount of memory you set the NVIDIA to run with. Once in windows check the amount of total memory the NVIDIA or 8600GT reports.
Example: You set the NVIDIA to use 64MB & the 8600GT has 512MB than the NVIDIA or the 8600GT should show 576MB. Its not that uncommon one buys a bad video card.
Reading the manual & windows not seeing the 8800GT tells me the bios did not see the 8800GT card. The card is bad. You’re doing just fine.
Sep 14, 2008 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Wavy display issue ... please assist!
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 18, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
1,580 people viewed this question
David Payne
David Payne
