Question about Canon PIXMA iP90 Mobile Printer
Only prints black in High-Res. Photo mode
Draft mode or anything else (including the various nozzle cleaning, nozzle test page, regular test print, etc.) gives no black whatsoever. Zero.
High res. mode works fine. That tells me the printer is capable of printing (i.e. no plugged nozzles, print head, etc.), but there maybe there could be some driver glitch. Any solutions?
  • 4 more comments
  • yogacharyadh Feb 07, 2009
    I should have added that I print from a Macbook Pro running OS X Leopard version 10.5.6.
    The driver for this printer/OS combo hasn't been updated since November 2007. Current driver version number is 4.8.3, both on Canon's website and on my machine. I have downloaded and re-installed in the past.
    I haven't ever found an open source driver for this printer, though I have found and used them successfully for other printers. Sometimes they work much better than the OEM driver.
    Any other ideas?
  • yogacharyadh Feb 08, 2009
    Any other ideas?
    Maybe you didn't read the original posting. I understand the difference between draft and high res. My printer prints beautifully at high res. That means the both cartridges are full or at least operational! Changing them is hardly going to make a difference.
    Other suggestions?
    I have uninstalled and re-installed the original software multiple times. No help.
    Others?
    Thanks for the effort. But I run a Mac, and I'm not planning to buy a PC just so I can print to this printer!
    If anyone out there can find an alternative (Mac OS X) driver, I'd love to try it. I do know how to search the net, and have been looking!
    Thanks--seems to be fixed now! Maybe the driver did get corrupted somehow. Anyway, I did re-install again and did the check-box thing suggested above and it all's well now.
    Genius:
  • 2,035 Answers
  1. Open the Print dialog box by clicking on File and then selecting 'Print' from inside the application being printed from..
  2. Select 'Quality & Media' from the pop-up menu.
  3. Click the 'Grayscale Printing' check box to add the checkmark.
  4. Click 'Print'. Printing will now begin.
  5. And then try to print ..
Posted on Feb 08, 2009
  • 360 Answers
If you have the original software, uninstall the printer. turn off computer, turn off printer. turn computer on with printer still turned off. follow the software instructions to install the printer as if it were new.
if you do not have the original software, this -->link<-- will take you to where you can down load software, also has links for support for your unit including contact numbers. allow the page to load fully before navigating away from the page.
any more problems, let me know. please give this Fix Ya solution a Fix Ya rating if gets you printing again
clarkco
Posted on Feb 07, 2009
    Genius:
  • 1,011 Answers
Sir,
 It uses much less ink then the normal printer setting and it prints faster. I honestly can’t tell the difference between a document I printed in draft mode and one that I printed in the normal mode. However, you can definitely see a difference when you’re printing an image.
also Refill your cartridges. problem may be solved
thanks good luck
    President:
  • 1,990 Answers
Welcome to Fixya! You might try--Unplugging all Cables and Power from the Printer, Uninstall your Printer Software and Reinstall, Reboot your PC, Reconnect all Cables and Power. I will try and Locate you a Better Driver While you Do this Procedure. Please Rate My Response! Thanks!
  • Canon Master
  • 6,487 Answers
I would suggest you first to update the driver for this device to correct the problem that you're encountering right now...
Cx4200 does not print black
If the nozzle test doesn't print black, then no black ink is flowing.
Run a "head clean", and do the nozzle check again.
Feb 19, 2015 | Epson Stylus Office Equipment & Supplies
How to fix the white lines on my prints
Print a test pattern to see if that is good. If so, then you are probably printing in draft mode. Simple select text and photos in printer properties and that should take care of it,
Sep 07, 2014 | Epson Stylus Photo 810 InkJet Printer
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
Test page prints fine, but nothing else does
You need a new printhead, QY6-0049-000 around $40.00. Your printhead has worn out or plugged nozzles and cleaning won't help.
Jul 09, 2009 | Canon i860 InkJet Photo Printer
Printing Problem in Windows XP
Does it seem to print the Windows test page faster than the self test print? If so it is probably printing the self test in a higher resolution than the Win test print (Win test prints are usually printed in low res)
Try printing a simple graphic or document from a piece of software. First in DRAFT mode and then in the HIGHEST Quality setting. See if you notice the "jerky" sensation in the DRAFT mode.
It could be normal for you printer.
Oct 14, 2008 | Epson TM T88 Thermal Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Won't print text or test page
try with diffrent printer driver and see. bye
Sep 22, 2007 | Canon BubbleJet i560 InkJet Printer
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
Won't print on normal paper
Refer to my previous post about manual under head cleaning and follow the routine through. This will most likely get you going as sounds like classic blocked nozzles. http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 01, 2007 | Canon i860 InkJet Photo Printer
Canon PIXMA iP90 Mobile Printer Logo
16 people viewed this question
old marine
old marine
Corne Viljoen
