Question about Minolta magicolor 2350 Laser Printer
Where is the drum reset fuse located on the Minolta 2530 DL print
Minolta magicolor 2530 laser printer
Location of drum reset fuse
    Sergeant:
  • 183 Answers
You can find all details with picture shot on following website:
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2530dl/user_e.pdf
please post back if any changes and vote all answers.
good luck
Posted on Feb 07, 2009
Konica Minolta Magicolor 2530DL streaks. maintenance
Lift drum out, look down behind toner and you will see a glass lens.
Clean it with a soft cloth or tissue. Works every time.
Aug 24, 2012 | Konica Minolta Magicolor 2530 DL Laser...
How to reset the drum
Pull drum out, look at bottom back for a small fuse. You can get the fuses at Radio Shack for a couple of bucks. Replace fuse. Print till pictures come out all messed up then replace drum.
Feb 04, 2012 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2530 DL Laser Printer: reset image drum 2530...
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
I hate this printer.....
May 18, 2010 | Konica Minolta Magicolor 2530 DL Laser...
2530 DL problem printing, has a streak of white line all the way down the page. Has plenty of toner in it.
If all the toners are not empty, then you have toner or dust on the print head unit. Remove the drum cartridge and you will see beneath it a narrow glass, just be sure that glass is clean.
Jun 07, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Minolta 2530 DL "low drum" message
The drum loses its ability to accept the image after a fair number of copies
A lot of machines monitor the drum voltages required to obtain a good print and when they go out of tolerance the report the error as Drum Low
It is telling you that the drum is on its last legs before it stops printing
Make sure that the Drum Kit is a complete unit with cleaning blade etc and follow any instructions such as wiping the drum with a bit of the toner powder before it turns.
This acts as a lubricant and stops the cleaning blade from digging into the drum surface when the machine first rotates
Jun 01, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I have just replaced black cartridge & drum. Now when I print there is a 3cm blank strip of print missing on left hand side of paper.
Remove the drum and clean the glass for the laser lens that is located just below the toners in the middle of the printer.
Mar 01, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
White Lines
My magicolor 2430 dl prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
jim
Jan 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta magicolor 2350 Laser Printer Logo
867 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
