Question about Black & Decker 7448 1/3 Sheet Orbital Finishing Sander
Black and decker model 7404 1/3 sheet sander - not orbiting
Hello, I have a model 7404 sander . ubit runs( motor runs?) when turned on but unit does not vibrate/orbit for sanding. I have taken nit apart and shaft seems in good shape and borttom(sanding area) plate with pologon seems intact .... Any ide what is wrong ... and how to fix?
Thank You
Tom L.
  • ckorrf Mar 22, 2009
    HOw to clean the ******? I sprayed WD40 oil and blew out every orifice but still NO vibration/movement and the motor is SMOKIN.
  • Pieter Vleeshouwers
    Pieter Vleeshouwers Dec 31, 2016
    http://servicenet.blackanddecker.com/Pro... all is obsolete excenter connection worn on armature
    Sergeant:
  • 226 Answers
I read elsewhere of someone using JB Weld to fill in the pentagonal hole in the bottom plate, after coating the armature of the motor with a light coating of oil to keep the JP Weld from sticking. Assemble, and set aside for the JB Weld to set up.
tom
Posted on Jul 13, 2010
  • 2 more comments
  • tom walsh Jul 26, 2010
    I mixed up about 1/4tsp of steel-filled epoxy and plopped it into the pentagonal hole in the unbalanced rotating weight. Re-assembled the plate to the motor and let it sit overnight. It worked. Don't know how long it will last.
    tom
  • rcsec Aug 29, 2010
    Steel-Filled Epoxy? Cool Idea. Did you just mix the epoxy
  • Jerry
    Jerry Nov 17, 2010
    The JB Weld in mine is drying right this moment. I'll probably give it 24-48 hours to dry then I'll give it a shot. How's yours holding up after 4 months?
  • tom walsh Nov 17, 2010
    I used it for several days on the porch repair lumber. Were I to do it again, I'd put waxed paper into the pentagon on the plate before dumping in the filled expoxy. Then I could remove it from the plate readily, and sand it by hand to allow it to flex more readily. As it is, it will vibrate like crazy when you turn it on.
    I had a dab of expoxy that was left over so I could use it to determine when the hidden expoxy should have been cured.
    tom
Wear inhibitor part number 86355 has broken on you. When this part brakes it brakes into tiny pieces which then leave the case so it hard to tell whats wrong. They don't make this part any more as the 7404 was discontinued in October 1975. I hoped this helped. I have the same problem.
Posted on Sep 30, 2009
  • chas1952 Mar 24, 2011
    i have a plastic welder. i melted some pvc plastic in the hole and while it was still hot reassembled the sander quickly. its been working for quite a while now. it was an easy fix but a little costly with the plastic welder. but it did work. it was my Fathers tool and i am kind of attached to it.
  • Jason Elford
    Jason Elford Oct 09, 2015
    Any idea what this part looked like? Was it a plastic but that essentially attacked the motor to the metal bit with the hexagonal hole in the bottom plate???
Open the sander and simply use a nut in replacement for the broken part. It worked for me.
Guy
Posted on Jul 19, 2010
  • Jason Elford
    How did you do this? What sized nut?
Black and decker 7404 what sheets do i get
The standard sheets for this sander will be the same width as the bottom pad and about 1-2" longer. The sheets clamps under the clips at each end. Use a screwdriver to leverage the clamp up allowing the sheet to be inserted under the clamp and then let it down to clamp the sheet in place. On many older units, these clamps get weak over time and this can cause the sheet to slip out. By folding the end of the sheet over a time or two, this will make a small section of the sheet thicker and will help the clamp to hold it in place.
There is also a link here http://www.ehow.com/how_8384633_change-decker-7404-finishing-sander.html to change the sheet which is basically the same thing.
The actual pre-cut sanding sheets will be advertised as 1/3 sheet such as this http://www.amazon.com/dp/B00448EZ32?psc=1
It can be cheaper to by full sized sheets and cut them down as needed as you will get more bang for the buck.
Feb 27, 2015 | Tools & Hardware - Others
Yes, I am on my 3rd one. Your machine has destroyed itself, and must be replaced. Sorry about that. If you choose to do so, you can take it apart and see what I mean. ( I fix these).
Be blessed..
May 14, 2013 | Black & Decker 7448 1/3 Sheet Orbital...
Need new throttle valve
I just looked on ebay you can buy the orbital sanders for as low as $10.00 Even the Black and Decker is around $ 15.00 Cheaper to replace than to keep. Good Luck https://www.youtube.com/watch?v=Ff8iYu7JXvA
Nov 05, 2012 | Tools & Hardware - Others
Black & decker 7448 sander sounds & smells like motor ceased up. only makes a humming noise & feels hot.
could have had a bearing problem that caused the motor to cease up, It might be time for a new one unless you are handy, if so I suggest going to dewaltservicenet.com and downloading a breakdown for the tool and make note of how you disassemble it to find the problem, If it is the armature or field it might cost less to replace it.
Oct 23, 2011 | Black & Decker 7448 1/3 Sheet Orbital...
I need to remove the fan on my black and decker pad sander but theres no way to clamp the armature to unscrew the fan
Why would you want to remove the fan? There is a good chance that the fan is molded to the shaft and can not come off.
Jul 13, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
Need instructions for KA230E orbital sander please
hi thank you , some one has already given me a pdf file to down load the instructions ,thanks for your time ,if i need any more advice i no who to ask ,the" fixya team. " pat
Nov 25, 2008 | Black & Decker 7448 1/3 Sheet Orbital...
Black & Decker 7448 1/3 Sheet Orbital Finishing Sander Logo
3,458 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
