Question about Philips Magnavox MS2530C 25" TV
White line at top of tv screen & picture flips back over itself
32PT5441 Panasonic tv, the white line is getting progressively bigger at the top of the screen and the picture seems to flip back over on itself. The only option a servicer gave us was to send it in for diagnosis then they would "see" if it was repairable, please help.....
  • 100 Answers
Caps in vert.output.
Posted on Jun 25, 2009
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
PT-51G44
Some of the components in the vertical deflection circuit area, and possibly in some other areas as well, have become thermo sensitive with age and use.
An experienced TV tech can troubleshoot the set to locate the defective parts and change them.
Jerry G.
May 08, 2008 | Panasonic PT-51G44 51" Rear Projection...
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
TV Problem
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Nov 11, 2006 | Philips 32PT5441/37 32" TV
Panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Aug 30, 2006 | Panasonic CT2722H TV
Philips Magnavox MS2530C 25" TV Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
