Question about Ricoh Aficio 1035 Copier
Aficio 1035 Drum problems
The tops and bottom of the copies were darkened and a horizontal line was on the top along with some gray streaks horizontally across the page. I took out the drum unit and cleaned it all up. Yes I touched the drum very carefully not to scratch it. I also blew it out with canned compressed air. Now the copies are all black. What did I do? Do I need a new drum? I have taken the drum unit apart thinking that I needed a drum cleaner and I wanted to find the part. Please help.
  • 1 more comment
  • mammol Feb 07, 2009
    I have cleaned both the small auto feed glass and the large scanner glass. This problem is likely because I messed with the drum assembly. I wonder if there is special way to clean the drum of if you touch it it takes some properties from it and it cannot be used any longer. The toner is stuck all over the drum when you look at it. I could send a photo.
  • mammol Feb 08, 2009
    I have tried cleaning the glass - real good. I think I need to look into other malfunctions with the drum.
  • James Louie Puro
    James Louie Puro May 11, 2010
    have tried cleaning the scanning glass plates?
    clean the glass thoroughly with a water and a tissue (scrubbing it gently a few times), and let us know if this made a difference with the copies.
  • 162 Answers
Disassemble the cylinder and you clean the load roller, probably for use compressed air it is dirty, cleans all the interior and it proves.
Posted on Aug 29, 2009
  • Delfor Tomás Acosta Aug 31, 2009
    Clean the charge roller and bushings.
  • Delfor Tomás Acosta Sep 25, 2009
    It can have twisted the contact of the charge roller that is in the
    later part of the image unit, this will cause a been accustomed to copy black…
    It can have been separated of the drum the roller of charge by some
    reason …
    It can be
    damaged pack of charge…
    Problem Solver:
  • 5 Answers
If you clean the drum unit, but the copy is dark push the drum unir forward because the luck is not locked
Posted on Jun 17, 2009
I have a xante 502 it has streaking on the top side of printing I printed each color and streaking is on each color with black the worst what part do I replace?
if you are familiar with ilumina menu search for the ID Test Pattern. Print test using 11 x 17 page.
On the copy you will see which of the drums need to replace, if the copy has vertical or horizontal lines on it the drum which ever color shows it has to be replace.
Jun 19, 2014 | Xante Ilumina® 502 Laser Printer
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
Aficio 1035 very poor copy only faint blurred image at top of page
try to go yellow +107 and hold red cancel 5 seconds and enter to copy sp and do 2207 and # 2 on's
Apr 07, 2011 | Ricoh Aficio 1035 Copier
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Getting horizontal red streaks across printed page
The drum roller is damaged. You must be careful and spin the cylinder. do not touch the roller. You probably have a line in the roller that causes this issue. Each time i have seen this problem, this was the cause.
Feb 12, 2010 | Brother MFC-9840CDW Laser Printer
The streaks are full page on both edges top to bottom and occur with printing and copying.
I suspect the drum unit might done its time.On this model you might find you can do 50000 to 90000 copies on your drum before it is done.First replace the drum.If problem sill presist the fixing unit can be the cause of the lines.
Dec 01, 2009 | Canon imageRUNNER 4570 Copier
Horizontal lines appear every 4 inches on each
User manual page 6.17 says:
Horizontal streaks indicate improperly installed or defective toner cartridge. Try re-installing the cartridge.
http://downloadcenter.samsung.com/content/UM/200607/20060712143739406_ML-1710_English.pdf
Nov 28, 2009 | Samsung ML 1710 Laser Printer
Gray Lines print onto copies
more than likely its your drum unit could be upper fuser film but prob the drum
Oct 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Ricoh Aficio 1035 Copier Logo
417 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
