Question about Insignia NS-8PDVD
DVD player plays 10 minutes and then freezes screen.
My Insignia NS-8PDVDA Portable DVD player loads and plays a movie fine for about 10 minutes and then the sceen freezes. Then I have to turn the whole thing of and load again.  It will not forward or stop after freezing.  How to I fix this or is it toast?
  • Anonymous Feb 11, 2009
    My Coby DVD player freezes all the time while I am driving. The movie starts up and a few mintues later the movie freezes and starts again if I shake it. I just purchased the DVD player last month. Do you have a solution?
    President:
  • 814 Answers
You may have a problem with the transport of the dvd laser. Open the compartment that you place the dvd into. You will see the spindle,the laser lens and the transport device that moves it during operation. The transport system operates on system of gears and drive rails. You must check and clean the drive rails and gears. Use a can of compressed air and blow all the dust and debris from the dvd compartment. Then use some cotton swabs with a small amount of isopropyl alcohol on the tips and clean all the rails and gears. Check the transport action by moving the transport to its most outer position and back to its most inner position. The action and travel of the transport on the rails should be smooth and easy. The gears should be clean and move easy also.These parts will require cleaning every month or so . Remember do not touch the laser lens with your hand. You should also check the lens it should look bright and shine. If not try cleaning it with a cotton swab and a small amount of alcohol. Rub the lens gently back and forth unit it is bright and shines.Now you can try playing a dvd and see if the player works properly. If this does not fix you problem. You can reset the dvd player to the factory settings.1.Press the setup button on the remote control.2.Use the left and right arrows to highlight the preferences page.3.Press enter to to enter the preferences sub-menu.4.Use the up and down arrows to find the default function and press enter. You now have reset the dvd player to factory settings Now again play a dvd to see if the player is functioning normally. If not you may have a more serious problem with the drive motor or power supply circuits. you can call Insignia customer service support at this telephone number.1-877-467-4289. Give them the model number of you dvd player and tell them the problem you are having with the loss of operation during the playing of a dvd. They will be able to tell you how to get testing and service for you dvd player. I hope this information helps you with your problem.
Posted on Jun 03, 2009
Where do I get a 6J05 AC 9V 1 5A adaptor replacement for for a NS 8PDVDA? And how much will it cost?
I would suggest going to ebay! Not sure how much it would cost but I'm sure they might have what your looking for. Hope this helps!
Aug 23, 2009 | Insignia NS-MVDS9 9 in. Portable DVD...
Insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
Nov 22, 2008 | Insignia NS-8PDVD
Insignia ns-pdvd8
You might have cooked it.  Do you know the power ratings on the car lighter adapter you used and do they match what's on the bottom of the DVD player?
Sep 17, 2008 | Insignia NS-PDVD8 Portable DVD Player
My PDV-705 Portable DVD
Durabrand portable DVD players are no longer supported because the company that made them for Walmart went out of business last Novemeber. You can contact Walmart for a replacement unit.
Jul 29, 2008 | Durabrand PDV-705 Portable DVD Player
How can I get a replacement LCD with my Insignia 8" portable DVD palyer model# NS-8PDVDA. THank you
toshiba HDD/DVD video recorder rd-xs30sb will no longer recognise blank dvd's. I did use them successfully in the past. Any ideas
Jun 12, 2008 | Insignia Televison & Video
Insignia IS-PD04922 Poratble DVD Player 2005
take a cotton swab with some alchohol on it and clean the lens, let it dry and try again.
Jun 09, 2008 | Insignia I-PD720 Portable DVD Player
INSIGNIA NS-PDVD10 Problem
I have a NS-PDVD8 . I purchased DEC 2006. I used it in April 2007 and then again in Jan.2008. When I went TO use March -2008 I received message NO DISCwhen attempting to play DVD.i messed with for an hour by rebooting and and dusting with compressed air.No help
next day I tried a CD and after very long loading time played music.
after I let it run for an hour I attempted DVD but same response.NO DISC
I cleaned the optical lens with a damp soft cloth and dried with soft cloth ( I do not recommend using a cloth but I was fed up and needed the player for flight next day) I believe you can purchase a cleaner kit.
I also ran the lens back and forth 5 or 6 times to make sure it could move fully along track.I heard clicking and wondered if this was ever going to run again.
I tried a CD first and the Cd loaded almost immediately and played
Next I tried a DVD and loaded successfully and played entire movie.
I turnred on and off about 10 times and reloaded movie without any problem.
Jan 23, 2008 | Insignia IS-PDVD10 Portable DVD Player
Portable dvd player wouldn't play the disc until shaken
I have an Insignia 8" Portable DVD Player (NS-8PDVDA).It has sound but no picture. The screen is a light grey. Appears as if its trying to come on.
Jan 20, 2008 | Insignia NS-PDVD8 Portable DVD Player
Insignia NS-7PDVD portable DVD player - no picture
The unit is failing and is not worth repairing. There is either a short in the wiring that leads to the screen, the inverter board os failing, or the decoder is failing. These are all hardware problems.
There are several tests to find where the problem may be, but the average consumer doesn't have the ability or access to parts to fix these issues.
Sep 22, 2007 | Insignia NS-7PDVD
Insignia NS-8PDVD Logo
724 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
