Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3000 photoprinter not working
MY PRINTER CANON PIXMA IP 3000 DO POWER UP BUT WHEN IT INITIALIZES IT CARTRIDGES DOES NOT MOVE AND ORANGE LIGHT BLINKS CONTINOUSLY.ALSO PRINTER'S PAPER TRAY IS NOT DETECTING.
    Scholar:
  • 127 Answers
Things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Posted on Feb 07, 2009
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
Apr 20, 2011 | Canon PIXMA iP1300 Printer
My canon pixma ip 3000 is malfuntioning, it flashes orange lights everytime I turned it on. can you help me what to do? thanks
Hi there!
Please try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt. If this doesn't work you can also try to reset the waste pad by turning the printer off. Then hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Then press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more.
Hope this helps.
Mar 30, 2011 | Canon Pixma iP3000 All-In-One InkJet...
My printer is canon pixma ip 1980, its orange light is blinking 7 times, it says the cartridge is not installed properly (but i did not even touch the cartridge), how can fix the problem? pls help, i need...
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Canon PIXMA iP1800 InkJet Printer
Canon IP 3000 - ink absorber full
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
Jul 02, 2010 | Canon PIXMA iP1300 Printer
Ip 1880. green and orange light blink alternately but green stays longer at the third blink.cartridge also not moving. please help me.
try to reset ur printer. first off ur printer and take off the jack,just hold the grin light then plug the jack,and also hold the red light den move your fingers in the grin and red light
Feb 01, 2010 | Canon PIXMA iP1800 Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3300 flash 5 times orange
pixma ip3300 flash orange 5 times, i remove all catridge / remove print head and orange flash 5 times. help!!!
Sep 18, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Error 6A00
6A00 is AP position error. Check sheet feed unit.In worst case the logic board assembly is defective.
Mar 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
No print
Hi there you can try this.
Canon IP 2000 / 3000 INK counter reset
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal..
All the best Pineworks
Feb 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
140 people viewed this question
old marine
old marine
