Question about Sony Ericsson Z550i Cellular Phone
Playback failed THIS problem might be caused by using the wrong PC software
  • 50 Answers
You might have moved the specific files to some other location. For instance, from phone memory to external memory stick. Update the media player please.
Posted on Feb 09, 2009
Machine suddenly shuts off during playback or record - is this fixable?
When something goes wrong during playback etc, all VCR's will shut down to prevent tape damage, or further mechanical damage.
There are two possible causes for this problem. One is there is some sort of damage to the mechanism, possible a plastic part that is broken. The second cause is the mode switch. This tells the electronics what position the mechanism is in. If that goes wrong the electronics might think it is in eject mode when it's in playback, for example, with things going very wrongs as a result. All are fixable if you can get the parts!
May 02, 2016 | Toshiba Televison & Video
Dvd pink color
Usually it is a setting in the menu somewhere that causes this--if all else fails read the owner manual cover to cover.
I have seen several with this issue and all were a setting wrong.
May 28, 2012 | Denon Televison & Video
I can't hear the instrumental track when trying to record vocals on acid pro 6. What am I doing wrong?
you need to switch the monitor when playback on in the audio properties.
& use headphones to stop any feedback.
Sep 10, 2011 | Sony Acid Pro 6 Professional Music...
How to record on acer webcam
On Acer. Not sure which particular model that is, but the steps are all the same...
First you would have to have the camera software installed on your system..
then you can go to your all programs and find this software, depending on the software if full-featured it should give you the options to do a lot of things,record, snapshots, playback, edit... etc...
if all fails, there may be a secondary full-feature software that can be used with your Acer... may have to look into that then
Jul 30, 2010 | Acer Aspire 3610 Notebook
How do i change my region code back?
There are three options you can try: 1. download the DVD drive's firmware from the manufacturer and re-flash the drive's firmware, this will reset any region code in 99% of all DVD drives. http://www.ehow.com/how_2316521_flash-dv? 2. you can use software that, in realtime as you play the videos back, removes region code out of the file transfer stream from DVD to playback software. The best software to do this that I know of is called "AnyDVD". http://www.slysoft.com/en/anydvd.html 3. use region free DVD playback software like VLC, which is freeware. http://www.videolan.org/vlc/ The first option is the riskiest, if something fails while flashing the firmware, it could disable the drive, but it is 100% FREE. The second option involves buying software and making sure its running before watching any DVD's in the future. The third option is probably the safest, cheapest, and simplest for you. The DVD drive is not going to prevent playback of a region 1 or 2 movie if its set to region 4, its the playback software that makes this decision. If you rely on commercial DVD playback software or Windows Media Player, they will not allow the playback. VLC is region free, it doesn't even check the region the DVD was produced for.
Apr 10, 2010 | Philips DVP5992/37 DVD Player
I have no speakers, trying to use headphones
possible causes:
  1. volume was muted on PC
  2. volume was too low
  3. plug to wrong jack
  4. faulty headphone
  5. audio driver was not installed (check Device Manager)
  6. faulty audio driver
  7. use the wrong device for sound playback (Control Panell > Sound and Audio Devices > Audio tab)
Jun 19, 2009 | Audio Players & Recorders
Virus or bad sound card
check your ram .also i think your hard diskl had bed sectors
no woorry if u have winodws xp bootable disk
boot your ssytem wiht it
run the chkdsk /r command.
but first chek your ram fix correctly in slots
that it.
Sep 29, 2008 | Computers & Internet
Sony ericsson w200i mp3 playback problem
I was facing the exact same problem with my W200i. I formatted my memory card using the "Quick Format " option and then re-uploaded my songs. That solved my problem. There is no disturbance in between songs now, also the "Playback Failed" error has also not occurred again.
Feb 10, 2008 | Sony Ericsson W200i Cellular Phone
DVD playback is warbling
Have you tried viewing in a different software, as i found that acer use a form of Power DVD as their standard movie player which comes installed with the system. Try viewing in media player for example.
Jan 12, 2007 | Acer Ferrari 4005WLMi Notebook
Video playback is not smooth while playing via USB 1.1
USB1.1 port can generally handle transfer speeds approaching 5.5Mbps between PC and DVD Camcorder. Smooth playback of movies requires 5.5Mbps speeds or above. If the PC you are using has some compatibility issues with the USB driver software, the USB port may drop to speeds below 5.5Mbps causing short pauses during video playback. It is recommended to copy the movie file from the DVD Camcorder to the hard disc drive (HDD) on your PC, then playback the movie from the hard drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony Ericsson Z550i Cellular Phone Logo
27 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
