Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Blow fuse our tv always blow fuse if we change it that fuse.
    President:
  • 1,077 Answers
If the TV keeps blowing fuses, there most be a short somewhere. Most likely the power supply board itself somewhere. But take it to a repair shop to find out for sure. The sad part maybe that you'll have to pay over $100 for someone to look at it.
Posted on Feb 07, 2009
Toshiba tv fuse blown
most electronic applications use what is known as a "slow blow" fuse and they are available fro electronic spares shops (JAYCAR and the like ) however if the fuse blows , you have a much bigger problem so take it to a repair shop and have the problem properly diagnosed
Feb 28, 2016 | Toshiba Televison & Video
Always blowing fuse in my astron tv..why?
It is possible that the fuse is damaged (if it is an automatic one). They are prone to damage after first shortened circuit. Try to plug in your tv elswhere and see if the issue repeats itself.
Apr 07, 2014 | Sylvania 6432GG 32" TV
My sony tv model KVJ21WF1 always blow fuse,power regulator okey
There is short circuit fault inside. unless this is rectified the fuse fault will remain.
do not try repeatedly some other costly component may fail.
Apr 22, 2010 | Televison & Video
Changed the fuse but it blows again
check the horizontal output transistor for short.
Apr 06, 2010 | Sharp 25R-S100 25" TV
No power to my tv set. fuse blow. but there is no fuse rating
When a Fuse "Blows" NEVER just replace it. One must always find the exact cause for this, otherwise there is a risk of fire or even explosion... The reason a fuse Blows, is due to a short-circuit of some sort, to earth. Occasionally a fuse may spontaneously fail... but this is rare. These types of problems must only be sorted out by qualified service man/center.
Jan 28, 2010 | Philips 27PT543S 27" TV
My phillips 42" flat screen model number 42pf7621d/10 keeps blowing the fuse in the plug usually after we have turned the tv off and its in standby mode or overnite when we sleep ive just change...
What is rating of fuse in your TV like amperes and volts.
There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two.
You can increase little bit current rating of fuse to avoid blow off.
Oct 01, 2008 | Philips Televison & Video
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
FUSE BLOWS EVERTIME I TURN MY TV ON. I CAN REPLACE THE FUSE AND DISCONNECT THE FLYBACK FROM THE CRT,TURN THE SET BACK ON ,CHECK THE FUSE IT WOULD STILL BE GOOD,BUT WHEN I REINSERT THE FLYBACK AND TURN THE...
Possibly a resistor that's becoming defective... it's changing value thus increasing current. like if the resistor has a rating of a 10k Ohm and now it's changing to a 30K Ohm and the current (amps) is supposed to be around .50Amps and now it's rising to .75Amps or higher, so it would blow the fuse so as not to further damage any other high voltage or sensetive component. Is the fuse you are replacing the same as rated for the tv? ie; 250V 1.25Amp FB (fast blow) or SB (slow blow) it should say on the circut board where the fuse plugs into.
Jul 17, 2007 | Zenith C27A24T 27" TV
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
569 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
