Question about Frigidaire Washing Machines
Frigidaire fwx833as2 getting water on floor in wash cycle
When washing large loads in wash cycle it appears as though the water is being spun up and over the top of the drum is this a problem with the transmission it is a frigidaire model fwx883as2
  • nascarfan13 Feb 07, 2009
    It drains fine in the spin cycle it only gets water on the floor when in agitate mode I had had an older amana washer that did the same thing after 13 years of service and had to replace drum brake pads however on the frigidaire there are none was wondering if braking of the drum is controlled thru transmission
    Scholar:
  • 51 Answers
Actually there are three fairly common causes for this:
The machine may not be properly leveled, and will go out of balance when spinning, no matter how carefully you load it. The drum tilts to one side and sloshes over the gasket at the top.
The pump might be blocked up badly, causing the water to not drain adequately, which can cause the water to be forced upward and out due to the building centrifugal force. These machines are designed to drain as they spin at a fairly steady rate. If something interferes with the draining, but doesn't slow the spin down, this can result.
Finally, the maximum water level switch (sometimes also called an overflow prevention switch, among other names depending on manufacturer) may be faulty. Normally your water level is controlled by the load size selector. However, on some machines the maximum load size setting is actually limited only by the overflow prevention switch. If yours is one of those, this could explain your problem.
Posted on Feb 07, 2009
During the wash cycle, an error HE appears, and the wash cycle stops. the clothes are soaked with water
Hi areej, this is AP! Thank you for your post.
I understand you are experiencing an HE indicator during the wash cycle on your Frigidaire front load washer. I would recommend contacting a local technician as this appears to be a problem within the motor speed control board. However, I would recommend a local authorized technician to come out and properly diagnose and repair your front load washer. I hope this information helps.
Mar 05, 2014 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Frigidaire top load washer will not drain Model # FWX833AS2
Check your lid switch for continuity.
No continuity, replace the lid switch.
Mar 12, 2009 | Frigidaire Washing Machines
Frigidaire FWX833AS2 water wont drain on spin
loundry washer is not emping the water. every other cycle is work.
Nov 11, 2008 | Washing Machines
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
194 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
