Question about Aprilaire 550 Humidifier
Hooking up a used 550 to a new 80% trane UD-R9V,
I'm confused why I'm getting 14v off of the B/K and R terminals for my humidistat on my new Trane variable speed 60,000 BTU 80% furnace? Here is the Trane schematic, Page 15, note #9 explains the installation for the TUD060R9V3K
 http://www.aireng.com/clientuploads/Trane_Data_Guides/Furnace/tud_r9v.pdf
It also tells in the manual to snip the w/14 loop on the board, which we didAny help would be greatThanksWill
  • brian baldwin May 11, 2010
    when the bk jumper is cut, it prevents the fan from running at full speed unless there is a call for fan at the bk terminal. with the bk jumper cut, you will only get about 80% fan speed. it really isn't necessary to cut the jumper to get your humidifier working properly. need to know if you have an air conditioner/heat pump hooked to this furnace and if it is a single speed a/c or heat pump. can you provide the model number of your outdoor unit.
  • 478 Answers
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Posted on Mar 12, 2009
I have an AprilAire 550A with bad humidistat. Can't find replacement. Got a 550 but wiring not right. Not sure what to do!
I believe they just updated model number descriptions. The basic design of that humidifier hasn't changed much over the years. I would go to their website and look for the one that is simiar to your model and get the humidistat for it. They are pretty basic devices as far as what the humidistats do. 24v power and common
Feb 23, 2013 | Aprilaire Humidifiers
Humming sound coming from my 550 humidifier thermostat. the dial to control humidity is not responding and wont turn off
Hello, sounds likemyou have either a bad humidistat or solenoid valve, disconnect the wires from the humidistat if this turns off the humidifier than replace the humidistat. If not the solenid valve will need to be replaced,
Sep 17, 2011 | Aprilaire 550 Humidifier
Trane furnace humidifier not working
If there is water and power to humidifier you need a new solenoid valve or humidistat.
Jan 16, 2010 | Honeywell Power Humidifier: Furnace...
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
HE220A direct wiring to protech 62-24084 control board
it is best to use a seperate transformer for the hummidifier, but in some cases you can use the low voltage t-stat wire that runs your furnace, you will need to have one wire run to common, and the other to the heating side of your low voltage, normally its the red wire hooked to the w circuit of your terminal board, if you do decide to go with an extra transformer, make sure you you have it wired to bring on the humidifier only when the unit calls for heat, hope that helps
Jan 19, 2009 | Honeywell HE260A1010 Whole House...
Humidifier was installed on return duct on new trane gas furnace
you are ok. this way humidity will get to whole house if your supply duct splits off. done this way often.
Dec 29, 2008 | Aprilaire 700 Humidifier
IFC on Trane furnace
If the manufacture says it is the IFC then you should have the IFC checked by the company who installed it if it is under warranty still
Jun 06, 2008 | Honeywell Power Humidifier: Furnace...
Loud "Glonk" when humidifier turns off
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Mar 12, 2008 | Aprilaire 700 Humidifier
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
Aprilaire 550 Humidifier Logo
388 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
