Question about Xerox WorkCentre Pro 423 Copier
WORKCENTRE PRO 420 U9 CODE
MY MACHINE SHOW U9 ERROR PLEASE HELP ME.
    President:
  • Xerox Master
  • 990 Answers
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Posted on Feb 07, 2009
  • krusnik May 30, 2011
    thanx it worked the stablizer was da prob
How do I reset error code u4 using the control panel?
Switch off the M/C then press & hold zero button & on still when screen will display (---) then press '10' start button '1' start button. now your M/C showing 3 so you change it press '0' button then switch off &on
Oct 10, 2014 | Xerox Office Equipment & Supplies
Message erreure U9
U9 in wc group is problem with HVPS. check charge & trf corotrons for leakage. isolate with removing charge or transfer corona each at a time.... U9 disappears; Reinstall HVT. Clean charge corona sawtooth & grid; tighten the grid on charge corona assembly.
Jan 23, 2011 | Xerox WorkCentre Pro 320/315 XL
My xerox pro 420 have U9 error?
The U-9 code means the main control unit/switch board has a problem, replace the board.
Jan 22, 2011 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
Error code u3-2 laser not detected?
You must have the Laser Unit replaced because the polygon mirror is not spinning up.
Mar 21, 2010 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox WorkCentre Pro 423 Copier Logo
580 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
