Question about Cornerstone Professional P1600 Monitor
Cornerstone p1600 flickering / arcing
I have a Cornerstone p1600, several years old. Started making arcing sounds and the screen flickers. Was happening every few minutes, now it's every few seconds. I'm going to open it up, blow out the dust and inspect it. I expect the problem is either the power supply or the CRT. If it's the CRT then this monitor is a goner. Has anyone experienced this problem? Where can I get a service manual? This has been a fantastic monitor, would hate to throw it in the trash.
    New Friend:
  • 51 Answers
Yes, dust accumulation will cause this and sometimes humidity.
You probably wont find much about arcing in a product manual.
The High voltage comes off the horizontal drive circuit through a transformer. Flickering says the CRT and the circuit is working. You just are getting a high voltage arc to a ground source before the CRT.
If you open this up, use extreme caution. You will be dealing with high voltage. Consider it a STUN-GUN! If you have a heart condition JUST SAY NO. Go shop for a new flat panel and recycle your old friend. I understand. I too am a hard sell if it can be fixed.
Place it in a dark room, turn it on and observe where the arcs are coming from and going to. TURN IT OFF. UNPLUG IT FROM POWER! (Most CRTs have an instant-on when plugged in)
Locate the suction-cup looking connector and wire on the back of the CRT. Use a vacuum first to remove as much dust and lint as possible.
The auto store sells ELECTRONIC CLEANER as well as SILICONE GREASE (for sparkplug wires). Do NOT use any thing that will leave a residue.
Clean the entire wire, connector and socket and any other area that you may have found in the dark test.
Use the silicone sparingly coat the contact area of the socket and wire.
IF there are other arc issues somewhere you may use silicone grease or silicone rubber to repair.
Good Hunting!
Posted on Jun 06, 2017
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
I have a Tevion 32 inch LCD (Model LCD3210id ), purchased from Aldi stores about 4 years ago. The screen has started flickering and it is making a slight crackling sound from the back. One, has anyon
Those sounds would be either your power converter/supply inside the TC or/and faulty cabling inside that has been worn out resulting in noises and flickering.
Dec 24, 2012 | Televison & Video
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
On a 3 month old laptop don't even bother finding out why just get it back to get fixed under warranty. The flickering can be from several things but unless it has been damaged there is no way you should have any problems even small ones with that new a laptop.
The flickering can be a bad connector or power problem which you might see on a 3-5 year old tired laptop but definitely not acceptable on a new one.
Sep 26, 2009 | Gateway NX560X Notebook
My 14 month old, 32 inch Samsung flat screen tv ''flickers'' The cable went 'out' 3 or more times and when returning the TV started flickering. We have unplugged & plugged it back in several times, but...
Check if this occurs regardless what the source of the signal, whether it is DVD or cable or a playstation. You can also check if the Menu flickers as well. If the menu does not flicker along with the picture it could be a problem with the source, probably your with the cable box or the port where it goes to on your tv
Aug 05, 2009 | Televison & Video
Picture flicker
You can get info at
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Flickering with a clicking noise
u have an arcing high voltage. dont use this it can cause a fire
dust might play a factor... i doubt it.
Nov 16, 2007 | RCA D52W19 52" Rear Projection Television
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
Cornerstone Professional P1600 Monitor Logo
70 people viewed this question
Top Cornerstone Computers & Internet Experts
Are you a Cornerstone Computer and Internet Expert? Answer questions, earn points and help others
