Question about Braun 4501 Electric Shaver
Braun 4501 shaver non-function...
The motor works, the battery seems fine (has 1.02 V.+-). When I plug the cord in and turn the shaver on there is a tiny buzz like a stalled motor, but that isn't it. I applied a 1.5 V. battery to the motor for a second and it spins just fine.
Where can I get a schematic? I suspect either the transformer or a diode (because I get no reading either way across the diode).
Any thoughts on this?
Thanks folks, I'm new, cool site!!
Bauer57
  • rob_b_bruce Feb 14, 2009
    Hi; I have the same problem. I've pulled apart the razor, unsoldered the battery, thinking it might be the problem, & jumpered across the battery connections with a piece of wire, but it still makes the same little buzz. I'm going to look for a board & just replace it.
You might try the original type battery (rechargable) Batteries Plus has them for less than 3 dollars, and they will solder the leads to the battery FREE! If you were lucky enought to get the 4501 apart, you may have problems getting it back together. Be sure front and back panels are free from the sides and it wont go back together unless you put the TOP snaps in first. Good luck...I got mine going for $ 2.78...
Posted on Dec 20, 2009
Power cord
braun 7030458 syncro shaver charging cord for electric razor braun 7526 adapter power cord replacement parts.
Jun 01, 2013 | Braun Syncro 7526 Electric Shaver
How do you get at the batteries in a Braun 4501 shaver? thanks
You will find replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
Oct 02, 2010 | Braun 4501 Electric Shaver
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
Feb 19, 2010 | Braun 4501 Electric Shaver
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Health & Beauty
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
I have a braun 360 razor. I yr old,seldom used, and it wont turn on.. I takes a charge and when i plug it directly in to the outlet it still wont turn on..
Your battery has degraded to the point that it won't hold a charge and also won't pass voltage/current and thus doesn't work even when plugged into the outlet.
You need to replace the rechargeable batteries to get your razor working again. If you want to do this yourself, check my other posts on how to access the internal circuit board and unsoldering the faulty battery and replacing it with a new one.
You can also contact Electric Shaver Service at 1-888-476-1785 to get an estimate for them to do the repair for you. They are reliable and quick with repairs usually done within a week from reciept.
Hope you find this Very Helpful and best regards!
Jul 16, 2009 | Braun 360° Complete Electric Shaver
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Braun shaver 5790 doesn't take a charge
Hi. As far as the Service Docs tell me, your shaver should have a pair of batteries. In recent cases the batteries are protected on the circuit board with a type of resin which makes it diffiicult to replace the batteries.
However, the docs say the shaver should work with the cord even if the batteries are flat. Perhaps it's your cord that needs replacing?
Mar 24, 2009 | Braun Syncro 7526 Electric Shaver
Braun 4501 shaver
go to the braun site for replacement parts or do a search in your browser for discount braun parts.
Sep 01, 2007 | Braun 4501 Electric Shaver
Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Jun 10, 2007 | Braun Flex Integral 6520 Electric Shaver
Braun 4501 Electric Shaver Logo
152 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
