Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Leaking My whirlpool washer was leaking at the time of filling the water,leaking from bottom front, please help
    Scholar:
  • 51 Answers
Ok, let's see what we can do here. First, you need to get the machine up in the front. Have an assistant help you raise the front. Pull it out from the wall some first for clearance. Place a couple of boards or other sturdy object(s) that are the same height under the front so you can safely get a good look under there. Look for rusty spots or obvious holes. If you have trouble spotting any, unplug the machine, make sure there is no water in it, and place a bright light inside the wash drum. Turn off the lights in the room and look underneath again. If you see any pinpoints of light, you've found your leak!
Now, many hardware stores and especially several appliance speciality shops sell "washing machine leak repair patches." These sound great, and they DO work. However, for a strip of patch about 3 inches wide by 6 inches long, they charge around $30.00
Save yourself some cash and have something handy around. Go buy a good 2 part marine epoxy. Mix it in equal parts and use an old spatula or popsicle stick to work the epoxy into the area where the leak is. It might be a good idea to sand the area with some medium grit paper first, especially if the surface is very smooth or has lots of rust. This will help the epoxy adhere better, and slow down the amount of time it will take to rust out again.
I've used this solution on several machines in the past 20 years and they tend to hold up for years before needing to be patched again!
Posted on Feb 07, 2009
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Whirlpool Duet Front Loading Automatic Washer - WFW9200SQ00
We're sorry to learn of your experience. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you, the website you visited (fixya) along with your model and serial number.
Jan 15, 2018 | Whirlpool Duet GHW9150P Front Load Washer
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron load Duet washer leaks
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from washer
you most likely have a pump leaking post your email so i can send you the manual
Nov 03, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
