Question about Amana ALW480DA Top Load Washer
Will not spin
I recently recieved an answer to the problem but when I open up the back to find the belt I didnt see a belt is there a belt for this model and if so were is it at and if it doesnt have a belt what can I do to fix the problem.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Access is in the front bottom panel remove 2 screws at bottom and panel will slip down remove spring under motor and tension level .
Posted on Mar 03, 2009
Side brush was replaced and was working. Now it spins sometimes but acts like the carpet is to high and it has a hard time spinning. Or like it's not on tight.
didnt specify unit --generic answer --remove cover and check belt ,for debris,and side connections/bearings damage excessive wear
Oct 23, 2016 | Vacuums
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
Detrola cd player spins too fast
Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
Aug 29, 2014 | Televison & Video
Brush wont spin
Was the belt worn or broken? It probably needs to be replaced. Here is the belt you need:
Dyson DC07 Belt
Apr 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Oct 17, 2009 | Kenmore Sewing Machines
Dryer wont spin, I changed the belt it spinned that day, but when I used it the next day it didnt spin.
Possible cause below:
Belt not in tension or not installed properly.
Faulty motor.
Drum is locked.
Other unrelated fault that had shown shortly after replacing the belt.
Regards
Jul 19, 2009 | Kenmore Dryers
Turntable spinning too fast
The turntable speed is controlled by a belt, which is virtually a big rubber band. If it spinning too fast , then this means the belt is too tight. The only way this can happen is for the unit to be fitted with an incorrect size belt. You didn't say if you have a new unit, or a second-hand one, or if it has recently had the belt replaced. If it is a new unit and still under warranty, take it back to the retailer and ask them to fix it for you. Again, if you have recently had the belt replaced, take it back and ask them to do the job again, and this time to please use the correct belt. Be polite but firm....If you are a handyman, the job is not too hard to do yourself, and if you need any extra help, just ask, johnatwagga@yahoo.com. To buy the correct belt, you will need the name, model number, and preferably, the serial number. All of these can be found on the back of the unit. Good luck, and I hope this helps.
Nov 24, 2008 | Teac GF-350 CD Shelf System
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
Washers isnt working
Most probably its your belt that has come off. Open up behind to check and refit. If belt is too loose, replace. The belt should "give" about half an inch after it is fitted. Or it would be too tight or too loose.
Dont forget to rate me please.
Dec 27, 2007 | Washing Machines
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Amana ALW480DA Top Load Washer Logo
47 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
