Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
Posted on Feb 07, 2009
The memory card is locked Taped side hole and switch in up position...I think unlocked. Still says card is locked.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1660
Points
10
You need to put memory card into computer and format it. your computer should pick up the memory card.
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
How do you unlock a Locked sandisc
That depends on the type of the SanDisk product.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory Sticks have a switch along one side. One position is marked "LOCK", the other position unlocks the card.
MicroSD adapters have a slide switch, just like SD cards.
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
8helpful
2answers
Memory card is write protected CoolPixS6000
2helpful
2answers
I have a panasonic Lumix camera and it keeps telling me my mempry card is locked. How do I unlock it?
Hello and Welcome to FixYa!
You can see the snap attached below;
If the lock switch is not on lock;
  • Slide the switch up and down. Repeat this 3 times.
  • Let it stay on the Lock position for 30 seconds.
  • Slide the switch up to unlock the card.
  • Try to transfer files into the device.
If none of the above works, then you card in either damaged (Format it) or is Password protected.
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
2answers
It says my card is locked when i put it the memory card slot
Hello and Welcome to Fixya!
Turn off the Device, put the Card out and see there will be a small switch/latch on some site of the card, and there will be stated the Lock/unlock state, if it is locked. change the position according to the description.
I'm attaching photos for your convince.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
3helpful
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
8helpful
2answers
How to unlock card??
Hi
there should be a little switch on the side of the memory card to lock and unlock it.
Keep us posted.
Unlock memory card
There is a little 'lock' switch on the side on the card with a lock symbol. Slide the switch to the unlocked position to unlock your card!
Aug 06, 2008 • Cell Phones
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
