Question about Gigabyte GA-7VRX Motherboard
My 7vRx can not start Windows...!?
Hi, i have 7VRX mboard, with CPU Athlon Xp 1800+, i had a problem with my system before, when my youngest brother misattached the banks of the Ram, after that the mboard did not start, some technisian fix it to me, now the problems are:1.the mboard can not work at bus speed 133 Mhz, so the processor can work only on bus 100Mhz.2.the system can not started up, even i tried to set up Windows many times, it stops at the stage of starting windows set up, althoght it passed the stage of copying files.Thanksmohamed
  • 2 more comments
  • mohandes2k Feb 07, 2009
    Hi, i tried the solution of loading the optimized settings of BIOS, the processor and now can work at 133 Mhz, but still i had a problem in installing Windows XP, the installation files are copied, and the system is hanged up at the step of starting Windows.
    thanks
    By the way, after 1st repaire of the mboard, the computer worked well.
  • mohandes2k Mar 07, 2009
    hi, i tried your suggestions, but the problem did not fully solved, most probabl there is a hardware problem in MBoard, i made the following traials:
    1.I replaced every thing in the system (CPU, Power supply, Ram and HDD)except the Mboard, but the problem persists.
    2.i installed windows XP on the HDD using another working system, and returned this HDD to my system, and boot the windows in safe mode, but the system stop when loading file MUP.sys.
    please help me to find a solution.
    Thanks
  • mohandes2k Mar 09, 2009
    Thanks for your patience with me, i verified that the windows CD is OK by installing windows on another system.
    thanks
    Problem Solver:
  • 17 Answers
One q? I have for you, are you trying to utilize more than 1GB of memory? If so, your computer will not work and windows xp installation will NOT work at all.(I went through the same problem, I have an Atholon XP +2600 1.9Ghz, for some unknown reason windows xp does not like more than 1GB of memory) Also, remember to get all of the upgrades from microsoft.com after you complete your installation of windows xp. You'll upgrd to sp1, then sp2, then sp3 in that order, you can't skip, just play it safe. Believe me, I went thru 2 and a half days of hell! before my system began to work.
E-mail me at tallcoolone100@yahoo.com if I can be of any more assistance. Hopefully, I could help.
Jeff
Posted on Jun 19, 2009
  • 565 Answers
Did the computer work normally after getting it back from the repair technician? Although there are other causes, the symptom that you state (stops at stage of starting Windows setup) may indicate a memory problem. Download memtest86 and run it from boot.
Also. you may have conflicts betwen the cpu and memory. If you set the system switch on the motherboard to 133MHz, you should check your BIOS (under Hardware Monitor and misc.setup) to see if the CPU Host Clock is set to 133MHz. Also, set the CK_RATIO dip on the motherboard to "auto".
Another thing to check in BIOS is the interupt mode...set it to APIC. The PIC setting will hang on XP. Don't forget to save changes on exit.
Your BIOS may be corrupted. When in BIOS, check to see if you are running main or backup. If it's running backup, use the AUTO RECOVERY feature to restore the main BIOS.
Your problem might be solved by just re-setting the BIOS by selecting "LOAD optimized defaults" on the main page.
There may be other solutions, but try these first. Please don't rate this post until we explore other possiblities.
Posted on Feb 07, 2009
  • 2 more comments
  • Bob
    Bob Feb 08, 2009
    Could be a memory problem, did you download and run memtest86? Could also be a hard drive issue. Insert your installation cd in the drive. When you get to the welcome
    screen select "to repair a Windows XP installation using recovery
    console, press R"
    It will take you to the command line. type in: chkdsk
    Let it run that, reboot and try to install XP again. Also, check your BIOS under "interrupt mode" and be sure that it is set to "APIC".
    .Thanks for the positive feedback and taking the time to vote.
  • Bob
    Bob Feb 09, 2009
    Correction, chkdsk needs to be ran ran with switches from thecommand line. chkdsk/r/f
  • Bob
    Bob Mar 08, 2009
    Sorry, but if that shotgun approach didn't work, my trying to help you through email is going to be very time consumming, not to mention frustrating for both of us.
    I recommend taking the computer back to the computer technician that you used originally. It sounds like he/she knows what he's doing and will be able to fix it for probably the same price as before.
    If you choose to pursue email, the only thing to do is start the troubleshooting process over. I will present you with _one_ question or task at a time. After you perform that task or answer the question, I need you to report back the result. I will then either ask you another question or assign you another task, and so on, until we fix this.
    Step one in this situation is to _verify_ that the Windows installation CD is OK. You will need to completely install Windows, using _your_ CD on another computer. If you don't have another computer available, you can take your CD to the computer shop and ask them to verify that it is OK. Should be just a small fee, if any. While you are there, tell him/her what's up, and they should be able to quote a ballpark price to fix your computer.
    OK, the ball is in your court now, I need to know if your Windows installation CD is verified to be good.
    Thank you,
    BobB
  • Bob
    Bob May 03, 2009
    Sorry I took so long to get back. OK, the install cd is good. There are a lot of things to check, but I would like to test your computer memory first. Are you familiar with Memtest86? It is available here (free): http://lifehacker.com/5132173/memtest86+...
    If you need a program to burn the ISO file use (also free):
    http://lifehacker.com/5100980/hive-five-...
    Download the memtest 86 ISO file, burn it with Imgburn, put it in your CD drive and boot the computer. Insert a paper clip in the little hole in the drive door if you have to. Let Memtest 86 run at least 3 or 4 passes.
Need integrated audio driver for Ga 7VRX. Reinstallation of windows XP pro did not install. Appears not to be part of windows CD. No audio output from any function of computer.
Try this link : http://www.nodevice.com/driver/GA-7VRX/get16816.html downlod the driver and install it. If the driver does not work google you will find it. it's best to try the manufacturer web site as offen they give option to download their products driver.
Jun 26, 2011 | Computers & Internet
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
Upgrading an OS on a GA-7VRX now orange LED and will not boot
Sounds like you've stressed the memory out during the upgrade, try just 1 stick at a time and see how that goes......please let me know ....cheers from Scott
Apr 14, 2010 | Gigabyte GA-7VRX Motherboard
What cpu can I upgrade to using my K7SOM+ motherboard? curently using AMD Athlon 1800.
Provided below is a list of all supported CPUs for you're motherboard from ECS; http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=316&MenuID=69&LanID=0
The highest CPU is:
AMD Athlon XP 2600+ (.13u) (256K,266,Socket 462)
Cheers'
Mike
Jan 30, 2010 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Have mboard w/ amd athlon xp 2200+ cpu can't
this is the Asrock brand of that motherboard, with the same chipset, so the front pin-out diagram should be the same:
http://www.asrock.com/MB/manual.asp?Model=K7S41GX
hope it helps :)
Jun 20, 2009 | Computers & Internet
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
http://support.asus.com/download/download.aspx?SLanguage=en-us
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Apr 16, 2009 | ASUS A7N8X Motherboard
GA-7VRX Motherboard won't boot
Hi sebaswis, am I correct that this Gigabyte GA-7VRX is a replacement MB? (I read your other posted questions). http://www.fixya.com/support/t1399506-computer_boot_when_power You mentioned you put your old system back together & it worked fine. If mother board is shorted to the system case you will see the CPU fan spin for a second. Most motherboards use a green led which represents there is stand-by power running to the board.(This is normal). I am unsure why your led is orange. (Its not mentioned in your manual & manual does not show the led?s location). Was the other GA-7VRX MB led always orange or was it also green? Suggest you disassemble the heat-sink from the CPU. You mentioned you installed a new XP 2500+ CPU. If a pin on the CPU was bent during installation of CPU into the socket or if no thermal grease was applied or too little to the top of CPU, either would give you: CPU fan spins for a second & nothing else seems to run. Look over the link provided below. It is a guide to how to install a motherboard. (You may not need this but Its worth going over all the steps). http://www.hardwaresecrets.com/article/145 As far as the power supply. If the MB's are the same (GA-7VRX) & the old system ran with 220W, the newer one should also function. Clarify these questions for me sebaswis. Mike
Dec 18, 2008 | Gigabyte GA-7VRX Motherboard
Computer won't boot. When power switch is pressed, CPU fan turns for a second but then stops. Nothing eles boots up, but an orange LED lights up and stays lit up on the motherboard. Motherboard: GA-7VRX...
1st. check your memory sticks, if you have two, flip\flop them around. if you can replace (don't buy them if you can until you are sure that they are damaged) or substitute them for a "lower" value & frequency range. Just to see if the computer turns on.
p.s. are putting the computer together for the 1st time?, Was the computer working before the problem? if so you could have said so!
MSI K7T Turbo2 No Manual
Hi, click on this MSI link which will open to the motherboard
K7T Turbo 2 (MS-6330 v5.0). Links for, Bios download, user manual & FAQ is listed at the top of the page in the blue in colored bar. http://www.msicomputer.com/product/detail_spec/K7Tturbo2.htm
You can run up to 1800 but it must be the AMD Athlon XP (Palomino, Socket A) up to 1800+
Aug 05, 2008 | MSI K7T Turbo2 Motherboard
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
Gigabyte GA-7VRX Motherboard Logo
108 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
