Question about HP Officejet Wireless Multifunction Printer/ Copier/ Scanner/ Fax
Officejet J6480 has scanner failure
This is a new machine (demo) with no warranty. Any ideas on how to fix this would be appreciated.
    Scholar:
  • 127 Answers
Sometimes cleaning the scanner glass plate would fix this issue.
turn of the printer.
wipe the scanner glass flat form with with a cleaning wipes or a plain water and a tissue (just a little water in the tissue). make sure the glass is clean with dirt and dust.
turn on printer.
hope this helps, please rate.
Posted on Feb 07, 2009
My mother board had to be replaced on my pc that
I always use HP printers and every time i get a new operating system (vista, win7 etc) the HP software does not fully install. I go to HP.com to install the latest software for the appropriate OS but rarely get more than just the printer working. If i require the scanner or cd print features i have to do that from an older computer or older operating system that the printer was originally installed on.
Oct 15, 2013 | United Stationers HP Officejet J6480...
Officejet J6480 won't scan. It indicates no
If you have the cd installer for your printer, try to install the driver for scanner... don't forget to disable first the connection of your printer from your computer when installing the driver...
If you don't know the location of the driver, try browsing first the cd installer..
May 26, 2010 | HP J4680 Office Jet All-In-One Printer
Officejet j6480 gives error msg scanner failure cannot copy, scan but will print from the computer
On the top of the scanner mechanism, there is a black tab that gets caught on the underside of the scanner surface, just beyond the glass, towards you. You will hear a gear grinding sound, that"s the tab getting caught. either bend the tab down, or remove it. Its on the black cover that"s on top of the scanner mechanism. Also remove any tape that is on the bottom of the trailing cable under the scanner that prevents it from moving all the way to the left.
Dec 18, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp officejet d145 carriage error & scanner failure
Re carriage error - suggest cleaning the encoder strip. this is the plastic strip running parallel to the drive belt but about 1 inch above it. They frequently become covered with ink spray and so are impossble to read by the carriage position detector.
Beware.
Only use cold water and be very gentle. also make sure you dry the strip thoroughly before switching the machine back on.
Re scanner problem 2 possibilities.
(1) make sure printer power cable is connected directly into wall socket not through an extension cable. This can reduce the voltage getting through to the scanner lamp.
(2) if that don,t work then I suggest you take the scanner apart and clean the reference strip. this is a white bar on the scanner glass which tells the machine what the light level is. This can be a bit tricky so if you've never done it before consult someone who has or get back in touch with me. HP don't want you to do this but it sometimes works.
Dec 11, 2008 | HP OfficeJet d145 InkJet Printer
HP Officejet 7130 "Scanner Failure"
Scanner failure usually means you'll have to replace the entire scanner unit.
When the machine turns on (or gets plugged in), does anything happen...any lights come on?
Is the machine able to print from the computer and recieve faxes while the scanner error is present?  If so, you probably need a scan unit.
Oct 29, 2007 | HP Officejet 7130 All-In-One InkJet...
HP Officejet Wireless Multifunction Printer/ Copier/ Scanner/ Fax Logo
489 people viewed this question
Ben Johnson
