Question about Brother LS-2125 Mechanical Sewing Machine
How to operate a Brother Compal DX
I havent used my brother compal DX for a year and it seems the needle cannot hold the thread whenever i try to sew.. can you help me how to operate and have an instructions to manage my problem..thanks
  • 360 Answers
This -->link<-- is the Quick Set-up Guide for your machine.
This -->link<-- is the complete Owners Manual for you machine.
It sounds like a threading problem to me. it is covered in the Quick set-up and the Owners Manual
Hope this gets you sewing again
Thanks for using Fix Ya, please take the time to give this solution a Fix Ya rating.
clarkco
Posted on Feb 07, 2009
Hi there, I have an old Empisal Compal ACE 765 sewing machine. After servicing the machine, I cannot get the bobbin and bobbin casing to line up in the correct timing with the needle. And I do not have a...
You can find a manual for for your machine in the link. In the photo below it show the same type of bobbin as your machine. It may or may not help you. It is a little fiddly if you have never done it but take your time and have lots of patience. Having a manual for your machine is invaluable.
Joness Brother Electronic Compal Ace Model 765 Sewing Machine Instruction...
Aug 02, 2017 | Sewing Machines
How to change Brother compal galaxie 870 sewing machine needle default that starts on the left to default to the middle
Some machines have the left setting as the default. Those machines have the bobbin case that is installed from the left side of the machine. For most purposes, this default cannot be changed to center. Machines that have the bobbin case installed from the front of the machine generally have the needle center default position. However, it appears to be a newer model machine (post 1970), so there is a good chance your machine has a needle position setting.
Brother Compal Galaxie 870 Service Manual free download schematics...
Brother Sewing Machine Manuals Instruction and Repair Manuals
Feb 10, 2017 | Brother Sewing Machines
The timing is out and was wondering how to fix it
Because the timing has been changed it will need to have a repairman fix it. Another possibility is to go to youtube timing sewing machines.
Feb 22, 2015 | Brother Sewing Machines
Where is reverse button on brother compal ace 765
It is located on the front of the machine on the lower right hand side.
Push down and hold the little purple bar.
Nov 13, 2013 | Kenmore 15218 Mechanical Sewing Machine
Brother sewing machine model 732 (pretty old machine) compal star My machine was sewing forward up to today. I broke a needle changed that since when it wants to go backwards...any ideas what to do I have...
have you checked the reverse lever to see what position it's in?
if the needle broke at the tip end check in the bobbin area for needle fragments
it is possible that a broken needle can jam up or even get the machine out of time.
it may need to be serviced
Aug 03, 2011 | Brother Sewing Machines
Computerized brother cs 100 keeps untreading itself while sewing
it is not threading properly
indicates that the needle /hook timing is off a bit or the bobbin thread tension is too tight
Sep 24, 2017 | Brother CS-100-T Computerized Sewing...
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
1,403 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
