Back to:
Tags:
M-Audio Audio Buddy Preamp Microphone
M-Audio Audio Buddy
By Hart - usenet poster
Hi Guys
Has anyone tried the M-Audio Audio Buddy preamp. It looks allright and
is very cheap. (Always on the look for a bargain) Any similar products
out there. Also does it connect via USB, or does just output a line
level signal?
Any comments or suggestions always welcome.
Alex
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It arrived and is smaller than I imagined. You're right, when I plugged
in a mate's condensor, it didn't seem to behave quite right, but it was
a pretty high end mic and you just wouldn't plug it into a cheap preamp.
With my Shure 57's and 58's it sounded pretty darn good and gives a
respectable amount of boost to noise ratio. Never had any problems with
clipping. I must say it's not bad. I use it to record a guitar and mic
into the Delta 410 and for that it's good value. Four stars I think.
Alex
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on M-Audio Audio Buddy:
I don't want to Accept this solution
Solution #2
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
The worst problem with the "Audio Buddy" is that its phantom powering is
completely non-standard. It will not properly power any microphone that
requires standard 48 Volt phantom powering; the open-circuit voltage is
only about 30 VDC. Also it has quite a low input overload point by today's
standards (around -17 dBu), and the "clip" LED is driven from the output
stage, so input-stage overload doesn't trigger any warning.
Outputs are on 1/4" phone jacks at consumer levels (-10 dBV).
The same company makes a much better product called the DMP3.
Thank You!
Solution #3
Not Rated (0)
maartenw
Rating: 0%, 0 votes
Which won't be for at least 14 days since they're out of stock :-(
Thank You!
Solution #4
Not Rated (0)
kioner
Rating: 0%, 0 votes
Wel I've ordered one so I'll tell you how good it is when it arrives.
Thank You!
Solution #5
Not Rated (0)
Peter1
Rating: 0%, 0 votes
They use very decent mic preamps, MAudio probably use an outboard
power supply for full 48v on the phantom power.
Ap
Thank You!
Solution #6
Not Rated (0)
jessie25
Rating: 0%, 0 votes
Take a look at M-Audios website you can download the manual in PDF format.
Might have all the info you need.
Regards Mark
Thank You!
Can you Help with these Microphones problems?
Microphones
I want to voice chat with one of my friend.Where do i have...
Microphones
What is the output of an astatis D 104 mike cartrtdge?
Microphones
SoundMAX Integrated Digital HD Audio
Microphones
I buyed a new and original Wii High School Musical for my...
Microphones
I have a DTMF mic that hooks up to my convertacom for my...
Loading problems.
Repair Service
Find Microphone Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
