Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Computer won't start.
I installed my printer today, and followed all the instructions. No dramas, so I shut it off.
When I came to turn it back on, however, things went pear shaped. Turned it on, and it went past the Vista loading screen, but just a blank, black screen after that. Re-tried a few times, but same result.
  • 2,427 Answers
Boot in safe mode (press F8 when booting and select safe mode)
do a system restore to a few days back
search it in the seach option in vista..
cause of problem,, driver crash..
Posted on Feb 07, 2009
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
I have windows 7 with a Lexmark x5400 printer, model 4425-001, my computer will not connect with printer. i can't get in to change the printer port to"enable bi-directional printer". it...
Try this approach instead:
  1. Uninstall your existing printer software from your computer. From your computer, go to Start menu > Programs > Lexmark X5400 Series folder > Tools > Uninstall.
  2. After the uninstall process, reboot pc when prompted.
  3. When pc turns back on, check if your system is running on 32-bit or 64-bit. From your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
  4. To re-install the printer software, please visit the Lexmark website. Use the link below:
- Lexmark X5470 Driver for Windows 7 32-bit- Lexmark X5470 Driver for Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation.
I hope this helps.
Nov 07, 2011 | Lexmark X5470 All-In-One InkJet Printer
I installed Windows 7 and now I have no connection to the computer. The printer is connected to the router but won't communicate with the HP G60t-200.
Try to remove the existing printer driver from your computer. Go to Start > Programs > Lexmark Z2400 Series > Tools > Uninstall. Your computer will then uninstall the Lexmark program. After the uninstall process, reboot pc when prompted.
When your pc turns on, check if your operating system is running on 32-bit or 64-bit. Go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to re-install the Lexmark Z2400 Series printer driver: - Lexmark Z2400 Series driver for Windows 7 32-bit - Lexmark Z2400 Series driver for Windows 7 64-bit
Download and execute the file. Simply follow the instructions on your computer screen.
I hope this helps.
Oct 26, 2011 | Lexmark Z2420 Printer
Printer failed to print due to error in printing system
Delete the printer from your system and reinstall it. If you need the driver, find it at
Delete the driver, shut the computer down, disconnect the printer, turn the computer back on ... run the HP printer software and follow the on screen instructions.
This will solve your troubles.
Thanks for your quesiton today.
Feb 06, 2011 | HP J4680 Office Jet All-In-One Printer
Printer will not print in windows xp
This is form OkiData's support site; The link will take to where I found this information.
Support Okidata
Hope this helps and GOOD LUCK!
  • Description: ecblank.gif ecblank.gif ecblank.gif
    ecblank.gif The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available. Follow the instructions below to correctly install your printer.
    Select "Oki Data ML 320 Turbo/D (IBM)" from the XP CD.
    The ML390/1 Turbo Printers are not on the current XP CD. Please use the IBM Proprinter or Epson LQ driver for these models.
    The driver should automatically install once the printer is connected to the computer and powered on. If it does not automatically install, then do the following:
    1. Click Start, then Control Panel.
    2. Click Printers and Other Hardware or Printers and Faxes.
    3. Verify that the printer icon is not already installed
    4. Click Start, Turn Off Computer, then Turn Off to shut down the computer.
    5. Connect the data cable either USB or parallel. If it is not then continue to step 5.
    6. Turn on the printer.
    7. Turn on the computer.
    8. The printer will now be automatically detected
Nov 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Installer Canon PIXMA iP1000 Printer
If you attached the printer FIRST, before you installed the CD disk that comes with the printer, you will have conflicting drivers.
When you install device without installing it's drivers, Windows 'sees' the device, and matches up one of the thousands of generic drivers it has.
You need THE drivers for YOUR printer.
Windows will have a conflicting issue with which drivers to use. The ones it matched up, or the ones you installed.
A Driver, is software that allows an operating system to 'communicate' with a device. (Windows XP is an example of an Operating System)
Should you have connected your printer first, THEN installed the CD disk, this is how to correct the problem,
1.Go to Start>Control Panel>Add/Remove Programs. REMOVE anything you see listed with Canon's name in it, pertaining to your printer. There may be more than one program.
You should be asked if you wish to restart your computer. NO!
Close all windows until you are back to the desktop screen, then shut your computer down normally. (Start>Turn Off Computer>Shut Down)
2.Computer off, and unplugged from the surge protector. (Electricity)
3.Press the Power On button in, and hold it in. Hold it in for a count of at least Five seconds. (Count, 1001, 1002, 1003, 1004, 1005)
4.Let go of the Power On button. Do this procedure Two more times.
(Number 3 and Number 4)
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
5.Now plug the computer back into the surge protector. WAIT 1 minute. Turn the computer on.
6.After Windows has fully loaded all the way, and any programs you have in the Start Up menu have loaded, install the CD disk that came with the printer. Follow the installation instructions.
7.Once the installation is done, you can restart your computer if asked. If you are not asked, go ahead, and restart your computer.
8.After Windows has fully loaded, and any Start Up programs have loaded, plug the USB cable from the printer into your computer.
9.Plug the printer into the surge protector. WAIT 1 minute, then turn the printer on.
You should see, "Found New Hardware", and possibly, "Found Canon Pixma ip1000"
Aug 02, 2009 | Canon Office Equipment & Supplies
This printer has always worked - today there is no light and my computer says the printer is offline. we've tried 3 diff plugs, all connections are good..
Your printer is not communicating with the Operating System.
Follow the following steps:-
1.First uninstall the printer. ( Make sure you have the printer driver disk )
2.Make sure the printer is OFF and disconnect the power lead to your desktop or laptop.
3.Leave the computer OFF for 2 to 3 minutes. I actually mean turn it off and disconnect your power cord to the computer. That will clear everything.
4.Plug in and on your computer and let it boot up. When its fully booted, click START / SETTINGS / PRINTERS and FAXes and click ADD A PRINTER.
5.Follow the instructions and have the appropriate driver disk or files on your computer to complete the installation.
Remember, most installations require the printer NOT be powered up or connected while you load the drivers. That is normally the last step and the driver loading will prompt you to turn on the power and make the connections.
Then you probably will have to reboot and you are done.
Jul 23, 2009 | HP Photosmart C4180 All-In-One InkJet...
I haven`t got a installation disk for my printer, so it won`t connect to my computer .
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Sep 04, 2008 | Lexmark P706 Photo Jetprinter InkJet
Black lines in display and printer will not turn off with on/off button
If your printer does not function properly, or communication error messages appear when using your printer, you can remove and reinstall the printer software.
  1. Click Start®Programs or All Programs®Dell Printers®Dell AIO Printer 946.
  2. Select Uninstall Dell AIO Printer 946.
  3. Follow the instructions on the computer screen.
  4. Restart your computer.
  5. Insert the Drivers and Utilities CD, and then follow the instructions on the screen.
If the installation screen does not appear:
    1. In Windows XP, click Start®My Computer.
In Windows 2000, double-click My Computer from your desktop.
    1. Double-click the CD-ROM drive icon, and then double-click setup.exe.
    2. When the printer software installation screen appears, click Personal Installation or Network Installation.
    3. Follow the instructions on your screen to complete the installation.
      If the problem continues, the printer needs to be serviced.
Aug 09, 2008 | Dell 946 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
59 people viewed this question
James Cagle
James Cagle
Jim Keysor
