Question about Vizio L32 32 in. LCD HDTV
No signal when connecting PC to TV
I've connected the RGB cable from the motherboard to the TV (LG 42PX5D), fixed resolution/hz properly... and selected RGB on input, yet the television screen still says no signal when I turn the PC on. I am really puzzled! Hopefully you know why =) Thanks No RGB signal message connecting laptop to VIZIO HDTV
  • Anonymous Mar 19, 2014
    I have an RGB cable hooked up from my laptop and into the RGB jack in the back of my Vizio television. After selecting RGB as the input, the message "No RGB signal Power will be turned off" appears on the tv screen.
  • 96 Answers
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Posted on Feb 10, 2009
  • 1 more comment
  • dominadorrey Aug 31, 2010
    Tnx so much. The manual sure did not help but your suggested remedy did the trick. Great job you are doing!!!
    Dominique in Fairfax, Va.
  • kalitr33 Feb 16, 2011
    i am having such a hard time with this plz help. i have a an hp pavilion vista laptop so theres no intel video card manger next to the clock and so i dont know how to access it. but heres what i did do. i connected the vga wire from my laptop to my vizio tv. ( tv and laptop were off) i turn everything back on and then togo the rgb channel and it says no signal, a box had opened up asking to cop or dupicate the desktop image to the tv, i selected duplicate and presed ok. nothing. by the way how do i access that box again? i cant figure it out . so then i restart it agiain, this time i press fn f4 ( button wiith the screen on it) and after i press it, it shows in the lower screen picture of a laptop arrow from laptop to tv or moniter. yet nothing happens. im all out of ideas. im browsed the web and found nothing.
    also i have an nvidia if that helps?
Thank You very much Misterixas going to graphics designer and changing from MID to Moniter worked thank you very much
Posted on Oct 03, 2009
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
Ive connected the vga cable and still get "NO SIGNAL" msg.
If the resolution of the source of the RGB signal is outside of the range of the set, you will get this mesage. The supported resolutions are listed in the owner's manual. Verify that you have a signal within that range. If you do, please post your source of the video here and we'll look further.
Mar 19, 2009 | Vizio VOJ320F1A 32 in. LCD TV
Cant connect to pc
It high definition digital signal. You will need a HD cable not a vga (that is analog).
Check in you tv manual. It should give you options of what cable to use. May need the HDMI cable.
Mar 08, 2009 | LG 42LG30 42 in. LCD HDTV
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Connecting pc to lg 32 inche
you have not mention the model of lg 32"   what i suggest is lower the resolution of your hp pc tp 800 by 600  and gradualy increase the res to get the picture which matches the plasma hope this will solve your problem
Nov 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
May 20, 2008 | Televison & Video
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Vizio L32 32 in. LCD HDTV Logo
18,100 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
