Ok so everything seems fine. The wiring harness and everything is hooked up correctly. When i turn key on all i hear is a grinding noise. Like CD is trying to load,but i get no sound no visual no nothing. Possibly thought it might be a bad ground,but with a bad ground it might not even attempt to load. Any help would be appreciated. I dont think its a bad unit. I think something is wrong with the harness or something other . When i took the Alpine headunit out and put the factory back in everything worked just fine. So any help would be greatly appreciated
I have the 9830 and my face plate flickers when the connections get dirty or loose. You almost have to push the face side to side and it comes back on. Its just a connection issue...common. Agreed cortrim1.
the cda 9830 and 9831 are known to have issues with the face plate connection that cause all kinds of issues. remove the face plate and clean the contacts on the face plate and the unit.
car radio has no power. 2000 ford ranger radio has no power but does have light when you turn on...
(More)
car radio has no power. 2000 ford ranger radio has no power but does have light when you turn on head lamps. took radio out and put back in now no power. checked fuses ok. is there a fusible link somewhere.
needs to installed in 2004 chevy cavalier and hooked up to ipod for power and play through stereo. ...
(More)
needs to installed in 2004 chevy cavalier and hooked up to ipod for power and play through stereo. I already have the older version in my car now
My sub output RCA is not sending a signal to my amplifier. I have an alpine CDA 9831 head unit and I...
(More)
My sub output RCA is not sending a signal to my amplifier. I have an alpine CDA 9831 head unit and I cannot find the function to turn the sub RCA on. Everything is wired correctly, the amplifier is powering up, RCA connection is using high end, low interference wiring, there just appears to be no signal feed. Second amplifier running mid's and highs is recieving signals fine, all speakers connected to that amplifier are running perfectly, it is just the sub's that are not kicking. Could you please explain how I turn that signal feed on?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
