Question about Superex #59-204 400W DC Power Inverter
Superex 59-158 User's Manual
I bought this Power inverter from an auction, thinking that it will be a useful power backup when power goes down due to hurricane. However, I got stuck with not knowing how to charge it as there was no charging cable or User's Manual included. Does anybody know where I can get a copy of the User's Manual ? I believe this is already an old model, so anything in the 59-xxx series might help.
Thank you.
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
What is the size of the glass fuse for the 59-204 400W power inverter ?
Hi
If it is the secondary fuse it would be 3.15amp or 4amp
Regards
Jan 31, 2011 | Superex #59-204 400W DC Power Inverter
Power inverter fan don't work
fan should come on when the unit has a load on it and it starts to get hot.
Jun 05, 2010 | Watts 75w Power Inverter 12v Dc To 220v Ac...
I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER
have you charged it,and check if the battery is still ion good condition
Jul 25, 2009 | NexxTech 175W Power Inverter
2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Mar 03, 2009 | Inverter Vector 400-Watt Power
Auto xs power station
Hi, i had the same problem and emailed the manufacturer. They suggested that i try to charge it up using a regular car battery charger, simply connect the crocodile clips to the charger and trickle charge for 3 to 4 hours. this worked for me. hope you have same success.
they did say that if this did not fix the problem then i needed to replace the battery, a used motorcycle battery will do the trick.
Feb 15, 2009 | Xantrex Technology XPower Powerstation...
Inverter Question
Where can I download Instruction manual for Fuji FVR-E7S?
Aug 27, 2008 | Xantrex Technology Ags Harness Cable...
Superex #59-204 400W DC Power Inverter Logo
443 people viewed this question
Top Superex Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you a Superex Electronics - Other Expert? Answer questions, earn points and help others
