I have a samsung DLP tv( model HLN5065WX/XAA) that when turned on ,after 5 minutes the picture turns greenish and the the display goes blank.Then you can here the TV humming.I have to unplug the TV in order to reset...the power button or remote does not respond.Any solutions on problem.
  • 3 more comments
  • poohbear3344 Feb 07, 2009
    I have had my TV for 4 years and this is the first time withthis problem. I believe it has to do with a capacitor or thurmal resister.
    would you know where I could get these parts ( part #) and about how much it would cost.
    Any information on where to get parts for this TV with part # so I can research prices
    Ant other suggestions on where to get patrs and prices
  • poohbear3344 Feb 09, 2009
    Thanks I will look into it
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for the problem may be due to
the board.Make sure the joints in the board
are done properly using soldering.These types
of unjoints in the circuit board will definitely lead
to these types of problems.This is the main reason
for this type of symptom.
check this out..
thank u..
Posted on Feb 07, 2009
  • Hariharanath V Feb 09, 2009
    hi..the parts will be available in the local
    electronic shops..
    try it out..
    thanks..
    hi..It is not a simple issue.It's a major problem.so
    please call your tv mechanic to attend to this
    problem immediately.
    check it out..
    thanks..
    Genius:
  • 1,665 Answers
Hi
This link refers to a similar problem.
http://forums.cnet.com/5208-13973_102-0.html?forumID=146&threadID=316698&messageID=2909034
It may not worth the repair. Better call a tech to inspect it. Good luck.
    Sergeant:
  • 250 Answers
U can buy the required parts from:
www.partstore.com
also u can get the parts prices listed there.
for any more help feel free to ask or else dont forget to rate the solution
    President:
  • 2,110 Answers
It is the color wheel. you better have the warranty. its pretty much the same cost as getting a new tv
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem unfortunately could indicate a number of probably faults from the power supply to the main electronics, to leaking capacitors or even heat related issues. A temporary workaround would be to force ventilate the rear of the Samsung (if at all possible) using a ventilator fan. If this resolves the issue or even just prolong the cutoff time, then it would be heat related.
Alternately, if you are considering a DIY (do-it-yourself), then pls be informed that this would require familiarity with electronic components & circuitry, use of a DVM/VOM and a soldering iron. It would be to your added advantage access to a Service Manual or at the very least a Schematic Diagram with voltage references. Additionally, you would be working on a live unit where dangerous voltages are present. Should you feel uncomfortable venturing a DIY, it may be to your advantage to seek the services of a qualified professional.
Good luck and thank you for using FIxYa.
  • 6,784 Answers
This, unfortunately is what we in the industry call a main logic board failure. it will stop showing completely soon if this isn't rebuilt of replaced. its has took out the remote sensors as well.
  • Michael Masters
    Michael Masters Feb 07, 2009
    i suggest total main board reconstruction/rebuild.
  • Michael Masters
    actually, the power supply board may be in trouble as well considering that you stated you hear humming. hope that helps ya and, thx for using fixya:)
    President:
  • 1,902 Answers
Check the solder joints on the main board. If the solders are bbad or not smooth and even means you are not getting proper flow and this is what is causing your problem
My Samsung DLP Tv turns off after about 3 minutes. What needs to be replaced?
i think it could be trip switch in the back of tv it should be a little blue button you can try put a bit of tape over the button it might work and if its that you can order a new one i put tape on mine and its still working
Feb 21, 2016 | Samsung HLS5086WX/XAA
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have no color on my samsung hln5065wx/xaa DLP tv. Is it my color wheel or bulb ?
If it is just no color but you still have a picture it should be your digital board. This is the board that mounts behind the light engine and should be encased in a shilver colored metal sheild
Aug 13, 2009 | Samsung Televison & Video
Samsung model HLN5065WX / XAA
You need a new color wheel. Go to www.samsung.com and do some searches. I had to have someone come out and replace mine.
Sep 06, 2008 | Proton MM2701VT 27" TV
I have a SAMSUNG DLP model HLR6167w with a problem. I just changed the light hoping this would fix the problem. When the problem first occurred, I could barely make out the picture, and it was very green...
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
