Question about HP Pavilion dv4000 Notebook
My memory card won't be read by my computer
I have a Nikon D60 and a Crucial 4GM high capacity card and I just formatted it but my computer says there are no pictures recorded. Any ideas?
  • 928 Answers
Try a different card reader that supports large cards. Sometimes low capacity readers will not read large capacity cards.
Posted on Feb 07, 2009
Nikon d50 camera 2 gb flash card how to format
See page 68 of the D50 manual: http://www.nikonusa.com/pdf/manuals/dslr/D50_en.pdf
Make sure you're using a compatible card. The D50 doesn't work with microSDHC cards.
Mar 01, 2014 | SanDisk 4GB microSD High Capacity Memory...
My Polaroid tablet ptab 8000 will not read a micro sd card. How can I format the sd card?
Will it read other cards? If so then it may not accept high capacity cards, or need to be reformatted. If high capacity is the issue the the only thing you can do is get a smaller card.
If format is the issue then take a computer and a memory card reader (if the computer does not have one internally), insert the memory card into the reader and go to whats ever disk utility you have select the memory card and format it to the specification of your device. Done. It may be a task to format a memory card from windows so use some type utility or the command prompt if you are familiar with using it.If it wont read any memory card then the reader built into the device has malfunctioned or not properly functioning--Good Luck.
Jan 27, 2013 | Cell Phones
D60 has SD card full message but the SD card is brand new and formatted.
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Sep 02, 2012 | Nikon D60 Digital Camera
After taking a picture with my D60 the shot is very slow to come up on the screen.Using smaller files speeds it up a little but it is still slower than my freinds D40x
Unfortunately this isn't anything that can be necessarily fixed per se.
I'd suggest looking at Nikon's website and finding any applicable firmware upgrades. However, upon checking Nikon's website there are no available firmware upgrades currently.
Beyond that, I also recommend formatting your memory card (after transferring your photos to your computer) and possibly looking into purchasing a faster memory card. Memory cards have different write/read speeds which can affect the rate at which your pictures come up onscreen in the camera.
Jul 24, 2011 | Nikon D60 Digital Camera with 18-55mm lens
My SD card won't stay in camera
Fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jul 10, 2011 | Nikon D60 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D60 transfer problem
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Aug 18, 2009 | Nikon D60 Digital Camera
Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Jul 10, 2009 | Nikon D60 Digital Camera
Unable to view photos on camera memory card
Is the camera shooting in RAW mode? If so, the files will not be in JPG format. Perhaps your Nikon download software converts to JPG for you?
I'm a Canon user myself, so forgive me if my terminology is not correct for the Nikon, but the theory is the same...
On my canon I can choose to shoot JPG mode, or RAW+JPG - this is the only way the card can be read directly on a PC.
Feb 10, 2009 | Nikon D300 Body Only Digital Camera
HP Pavilion dv4000 Notebook Logo
167 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
