Back to:
Tags:
NEC LCD1735NXM Monitor
NEC LCD monitor worth fixing?
By Peter1 - usenet poster
I have a 2-year old 17" NEC LCD Monitor (LCD1735NXM), which has
developed a faint buzzing sound, along with the screen going completely
pink intermittently. When I tap on the case, the sound changes slightly,
and the screen goes back to normal for a time.
I have an electrical background, but before opening the monitor, I thought
of getting some ideas whether this sounds like a bad soldering connection,
which may be fixable, or whether this could be the sign of something else,
and not worth fixing. Thanks for any feedback / experience someone may
have with these monitors. Ken
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Duke
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks for everyone's input! Ken
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on NEC LCD monitor worth fixing?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Putty
Rating: 0%, 0 votes
Oops, I missed that part. Yeah look at the inverter if it looks like the
backlight is going pink, otherwise look for signs of cracked solder
joints or loose connectors.
Thank You!
Solution #3
Not Rated (0)
man1
Rating: 0%, 0 votes
But tapping would not change the backlight tube mercury or anything
else within the backlight. Sounds like the previous posters were on
the right track.
H. R. (Bob) Hofmann
Thank You!
Solution #4
Not Rated (0)
Luisa_K
Rating: 0%, 0 votes
Sounds like the backlight tube is bad. The mercury depletes with age and
you can be left with a dim pink screen. This also changes the electrical
characteristics of the lamp which may result in the inverter buzzing.
Thank You!
Solution #5
Not Rated (0)
Cato
Rating: 0%, 0 votes
IMHO, probably a bad wire on a connector. I'd pull it apart and check
the connectors (the VGA input) wiring first.
The buzzing may be the backlight inverter. I'd guess it is not
related.
Thank You!
Solution #6
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
With a background, you should be able to work on it. Tap on local areas
once it is open. Does tapping ever cause the symptom? If it does, it is
going to be a lot easier to find the area of interest.
Look closely at all connectors and sockets once it is open. Tap them and
wiggle them.
Also, flexing circuit boards with an insulated tool is a good way to find
intermittents. Cold spray is also used, but I doubt it will be useful in
your situation.
Thank You!
Can you Help with these Monitors problems?
Monitors
I have no image on may samsung 204bw lcd monitor but the...
Monitors
i have a problem with my samsung monitor
Monitors
i have checked the cables and drivers and still need help.
Monitors
2 week old LCD monitor suddenly has a horozontal thin...
Monitors
my tower and my monitor both power on but the monitor...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
