Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do you remove the ink tanks in the pixma mp620?
I am having problems with the initial setup on my printer. It is making noise and i want to take the ink tanks out to see if that is the problem. But can't seem to get them out!
    President:
  • 1,902 Answers
They come out one of two ways. Either you push in and up or you push down and it pops up .
Posted on Feb 07, 2009
Color error black
Probably not. CMY all combine to make black, if one ink tank is empty it wont print black. Try going into print settings and change to GREYSCALE only.
Dec 01, 2013 | Canon PIXMA MP620 All-In-One InkJet...
How to reset cannon mp620 erroe code U072
U072 Some ink tanks are not installed in
place.
Install the ink tank(s) in the correct position.
This in write in service manual.If a have been useful pls give me a vote :)
Mar 07, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Loud clicking noise when attempting to print
Try removing the ink catridges and checking them for any damage like leaking ink. Then replace them and try to print. Also, make sure there is nothing stuck in the paper feeding tray.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My MP620 printer is all of a sudden not printing black, I have no idea why, there is still ink in the cartridge. Please help.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 29, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Canon MP620 ink tank out stalls entire printer
https://support.bchtechnologies.com/hc/en-us/articles/200701259-How-to-reset-Ink-level-Canon-30-241-PIXMA-iP-MP-MX-MG-Series
Jan 06, 2018 | Canon PIXMA MP620 All-In-One InkJet...
I want to chgange the black ink cartridge
Go to:
Canon MP620 Support
Select the "Support & Service" tab if it is not already showing.
Type insert ink tank in the space to "Please enter your question" block.
"How do I replace or insert an ink tank?" should be the first result showing.
Click on that link and it will open up detailed instructions with pictures on replaing the ink.
Thanks for using Fixya.
May 08, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Out of ink
In case you have not already found a solution....
Go to:
MP620 Support
Click on that link and it will open up detailed instructions with pictures on replacing the ink.
Apr 27, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I have a canon Pixma MP620 photo All-in-One Printer. I installed the print head and ink tanks gently and without problems. Lights lit up on all tanks. I closed the scanning unit and the LCD displayed the...
I found a solution if you get an error code. I just bought a canon mp620 tonight from Best buy. I followed it to the letter as far as putting the ink in. Closed the lid and it made some God awful noise. The code was C000. You need to COMPLETELY push the ink tanks down underneath their respected sticker letters. Goto www.usa.canon.com look under support. Type in your model number and look under FAQ'S. I also had the error 5100 code. It explains with pictures and instructions what to do. Hope it helps anyone with trouble with the error code c000 and 5100
Nov 16, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
