Question about Compaq Evo D500 PC Desktop
Weird hard drive won't boot
I have a home business working on computers, and its not often i come accost a problem i can't fix but this one got me.
Doing a routine disk clone, i'm swapping out an almost full 40gb for a 320gb hard drive.  The old drive is a seagate, the new one is WD.  Both are OEM drives.  When i put the new drive in after cloning the old one, it won't boot, if i put in the windows XP sp2 recovery disk, it boots fine.  Makes me thing it has a bad MBR, so i fixed the boot files and nothing.  Put an XP pro cd into the computer and it said the copy of XP is damaged, had it do a repair, still won't boot up.  Put the original drive back in and it starts up just fine.  I'm missing something but have no idea what it is.
  • 14 more comments
  • Ryan Hall Feb 07, 2009
    its not the jumpers, the HDD, CD and floppy are connected separately to the MB, Tried playing with the jumpers with no luck, that was one of the second things i tried.  A very big HUH moment.
    no error on boot unless i do a full post, than i get that the media may be unpluged, the HDD shows up fine in BIOS, and with a boot disk it starts fine, just need it to start on its own without a boot disk
    Yes, does seems like its not writing the boot files, just not sure how to replace them.
    tried that a few times in a few different ways, each one won't boot with out a boot disk.
    i can burn an ISO, i did that so i could make a recovery disk so i could get into xp, the problem is i need the disk for it to boot, the HDD won't boot on its own, tried copying the boot files from the XP cd with no luck on it booting
    This is what i get
    That was my next step, working on it away from home so didn't have another desktop, will try that later today, first trying to copy it to a smaller partition, see if it does anything.
    does not boot from another computer, does the same thing.  So that narows it down to the drive, question no, why doesn't it copy the MBR from the old drive..
    it does boot from a fresh install, just trying to avoid the pain in the rear part of copying everything over, mostly because its not mine and i want it to look identical when i'm finished.  i wish it had a place for a second HDD, i would just keep both in the system.  and i would like to know how to fix this if i ever see it again.
  • Chris May 11, 2010
    Wow, this is a tough one! Can you put the 320GB in a different machnie and see if it will start to boot in that?
    When you boot from the boot disk, open a command prompt and type:
    bootcfg /Query
    Does it show any entries?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    I found this on one of the forums hope it helps:
    I opened the cd using the my Fedora box and saw 1 iso file. I used roxio in one case to create the cd. This was the same way I created my Core2 cd set and they all worked.
    Answer:
    That way won't work. You have to convert the .iso file into folders and files. It is easy to do, if you have nero just select "burn image" from the file menu, and point it to the .iso file. It will convert it into the usable form. If you burn the .iso it will never work.
  • Randall  Trahan
    Is there any way you can clone it again?
  • Randall  Trahan
    The only thing I can figure is that the burn did not work correctly so you don't have a bootable .iso.
  • Randall  Trahan
    Go back to the basics..its booting past the hardware check stage so you need NTLDR to grab it from BIOS and get things started, NTDETECT.COM checks the hardware, BOOT.INI defines where the operating system is, then it is turned over to NTOSKRNL, HAL.DLL to bring up the Windows screen. If you can copy NTLDR, NTDETECT.COM, BOOT.INI AND NTOSKRNL to a disk you could get it to the operating system.
    Is there any kind of error message? Anything about boot.ini?
  • 70 Answers
Try putting it in and loading an OS onto it directly (Install XP Pro or whatever you have handy). Let the machine do the disk work fo you. See if it will boot that way. If it does, then you should be able to copy off the important files by hooking the old one up as a slave. It's a pain in the rear, but sometimes it's better to start with a fresh install of the OS.
Posted on Feb 07, 2009
How to set jumpers to run two hard drives
Haven't read anything about setting up either of them as slave and the other as master... if you don't do that... you get this sort of "HUH, what's going on." Not quite that simple, but not that hard either if you're IQ is probably at least 80, you should be able to do it... heck, half the drives have the jumper settings printed on them.
HP 530 won't see hard drive
Are you sure there is no usb / CD in the computer?
Try pressing F8 when the computer boots and select the HDD as the boot device.
If this works, you'll need to reset the boot order in the CMOS / BIOS.
Apr 11, 2013 | HP Business Notebook 530
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Home and business shutdown
If you have a bootable CD or DVD drive in your computer, download a copy of Hiren's BootCD, or Parted Magic, and boot to that operating system. Then you could copy the files off to another drive such as a flash drive or external hard drive.
May 08, 2017 | Intuit Quicken 2008 Home & Business Full...
I installed a new hard drive in my dell inspiron laptop service tag #4360rf1 and it won't let me reinsstall the operating system i get a no bootable sector on harddrive error
When you boot up the laptop press F10 to bring up an list of devices to boot up from, select the CD drive.
OR
Go into the BIOS setup and to the Boot start up and move the CD to the top as the first boot device with the hard disk as the second device.
Your laptop will now boot uo with the Windows Vista installation CD.
Apr 17, 2012 | Dell Inspiron 1720 JetBlack T5450 Laptop...
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Computer acts like it in standby mode will not power up, made a weird noise according to my daughter and quit
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 23, 2011 | Dell Dimension 4400 Power Supply ** FREE...
Replaced a crashing hard drive that worked a day, now it doesn't
Power supply blocks do weird things. If you can beg borrow or... a power block for your computer (500 watt, eh?), try that before you upend the computer. A power block has fixed MANY issues for me.
Is it possible to test the hard drive on a friend's computer? The store that sold the hard drive can likely test it for you, perhaps for nothing.
It sounds like you may be having a problem with the hard drive interface on the mother board. Try using the second interface. It is very unusual for a modern computer to be unable to detect a hard drive. You HAVE tried a new EIDE cable, right? 80 pin? Place the drive selector in the neutral position (no selection).
Mar 22, 2010 | Western Digital Computers & Internet
My hard drive is stuck in write protection so I cannot save to it even though I have more than 80% of the drive's memory still available. How do I fix this issue?
It is possible that it is the computer. Is this a business computer or home computer? Business sometimes protect against data theft by not allowing data to be saved to external drives.
Have you tried rebooting the system? I would suggest a full reboot including a power off.
Mar 12, 2010 | Western Digital WD Passport 250GB Portable...
Start Up Problem
i believed its not the mother board, check the system setting (press F2 when dell logo came out on screen) maybe the boot sequence is not configured right, try to set
First Boot: internal hard drive
and also remove any USB drive or floppy disk or CD inside optical drive or memory card connected to notebook before trying to boot the machine.
Apr 02, 2009 | Dell Inspiron 6000 Notebook
Replace hard drive on Compaq presario 2190US
NO its a software crash use the installation disk you said you used......go through the blue screen allowing windows to boot up from that disc let it go right to the end and press "R" for the console (the dos line ) when there enter ....     chkdsk /p
Let Windows fix any problems. When finished remove the disc and I bet it will open windows for you.  Please come back and tell me how did you do because most people that I helped with this problem just run but you know old saying "what goes around comes around"
Oct 14, 2007 | Compaq Presario 2190US Notebook
Compaq Evo D500 PC Desktop Logo
432 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
