Question about Nintendo Wii Console
Wii remotes will not connect
I have to wii remotes will not connect to the system. I have never had this problem, why all of the sudden does it happen?
  • Anonymous Feb 08, 2009
    I synced the remote to the system, and they still won't connect or even trun on now.
First turn your wii on open the sd card slot and there should be a red button and on the wii remote open the battery cap and there should a red button as well, so then just click the red button on the remote and then keep pressing the red button on the wii consle and there u go!!
Posted on Feb 08, 2009
  • 33 Answers
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 03, 2009
  • 155 Answers
SOURCE: wii remote not connecting
Sorry this took some time.....
You need to resync your remotes to your wii. When you have turned your wii on press the red sync button next to the SD card slot then press the sync buttons on both remotes under the battery cover. They should then both be connected. You can then change which one is no.1 and 2 by pressing the home button and going into remote connection or whatever it is at the bottom and clicking on reconnect. Hope this helps. :-)
Posted on Nov 15, 2007
frankgant
  • 250 Answers
SOURCE: HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Posted on Mar 29, 2008
SOURCE: our wii remotes do not
if you take the back of the wii remote you will see a small red button and if you open the flap at the front of the actual wii you will see another button the same as this one.press these two buttons at the same time and wait for a few seconds then that should connect the remote to the wii.
Posted on Sep 15, 2008
MrFixIt268
  • 52 Answers
SOURCE: How do you connect a second wii remote?
If the controller is sync'd and showing the light. Then all you have to do is select how many players. I would recommend calling Nintendo or their website to step you through this . :)
Posted on Jul 20, 2009
  • 67 Answers
SOURCE: Can't connect my Wii remote to the Wii
Take off the battery cover on the back of the wii remote and open the slot on the front of the wii where you put in the memory card:
http://g-ecx.images-amazon.com/images/G/01/ciu/09/d4/42196230a8a096736e5af010.L.jpg
Press the red button by where the batteries go in the remote and the red button by the memory card slot together and they should find each other and synchronise properly. If they ever lose synchronisation again just repeat the process.
Posted on Jan 01, 2010
My wii
What to do:
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure must be followed for each additional Wii Remote added to the system.
Ref: http://www.nintendo.com/consumer/systems/wii/en_na/ht_system.jsp
Dec 16, 2012 | Nintendo Wii Console
How do I hook up my wii to the intenet?
1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2. Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4. Select "Connection 1: None, Click on "Wireless Connection" and then "Search for an Access Point." and the Wii will display all the wireless networks it finds.
Visit the Wii Connection Troubleshooting Site for more info
May 29, 2011 | Computers & Internet
Wii remotes turn each other off when anouther is turned on ie wii remote is on try to turn wii balnace board on turns wii remote off
That is quite unusual behaviour from your Wii. In the forst instance it would be a good idea to RE-SYNCHRONIZE your remotes and balance board with your Wii
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote and that they are full/charged.
    Go to the Wii Menu. (Channel Grid)
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This procedure must be followed for each additional Wii Remote added to your system.
    (source http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch)
Option 2: There might be a glitch in the software which can often be fixed by re-downloading a fresh copy. Download the latest update by going to Settings->Console settings->Internet->Select your connection type->test connection. After the connection it will ask if you would like to perform a system update.
Option 3 If you are still having problems, try to identify if it is only happening when using a combination of some of the devices. Do you have the problem when the balance board is off?
There is also the possibility that there is a electrical fault with your wii. If the above does not help contact Nintendo support at http://www.nintendo.com/consumer/
Good luck
Mar 13, 2011 | Nintendo Wii Fit - Balance Board + Game...
No internet
How to connect your Wii to the Internet
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then chooses "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours Select "OK," "Save Settings," and then "Yes."The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates...
Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
Internet on wii
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point."
Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours Select "OK," "Save Settings," and then "yes".
Dec 21, 2010 | Nintendo Wii Console
We have bougt a new controller how do we get it to work with the wii home console do we press two buttons together to get it to work? Can you help thanks
Lots of people have this problem including me, what you do is turn the Wii on,( turn off other Wii remotes once done turning on Wii system), press the connect button on the Wii remote 1st before pressing the SYNC button on the Wii system. If the Wii remote you are talking about is like the classical N64 remote then i cannot help you at the moment but there should be a manual that tells you how to connect it. I can do some research for you if none of the following work.
Sep 29, 2010 | Nintendo Wii Remote Controller
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Sep 22, 2009 | Nintendo Wii Console
Wii Problem, the remote
make sure a combination of the 4 blue lights at the bottom of the remote are on (but not flashing, mind you). if they're not, this means that your wii remote isn't connected to your nintendo wii system yet. if when you press a button and none of the lights turn on at all, this means that there are no batteries in your wii remote. if it flashes, this means its trying to connect to your wii system. you might have to troubleshoot this a little bit. try to aim it at the bar that recognizes the wii signal (a separate piece that comes with the wii system).
hope this helps ;-)
Apr 04, 2009 | Nintendo DS Lite
Wii Remotes
Could it be an issue with your sensor bar on top of the TV? That could explain why you'd be having the issue with more than one remote all of a sudden.
Jun 29, 2008 | Nintendo Wii Console
Remote malfunction
Do the LEDs light up when you press the buttons on the Wii Remote? Try simply turning off the console, and pressing the power button a couple times firmly on the Wii Remote. If it turns on the Wii, the connection should be established. If it doesn't turn on the Wii, some hardware is defective. Recommend calling Nintendo Support if this happens.
Aug 14, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
802 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
