Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Flash card will not stay in it's proper spot.
Flash card will not stay in it's proper slot. I have to hold the flash card down with a finger and then force the door close. I am afraid if I continue to do this I will break my door. What can I do to solve my problem?
  • elvislive486 Feb 22, 2009
    I have the exact same problem. I have tried another card and it is exactly the same
  • 928 Answers
That means either the lock inside the slot of the canon broke or the latch on the flash card is worn out. Can you try another card and see if it locks in.?
Posted on Feb 07, 2009
When I send any folder always show me the disk is write protected remove the write protection or use another disk. for that I can't work properly. Please tell me how can I unprotected my usb flash. My...
This flash drive has a safety button located directly on it. PLEASE SWITCH THE BUTTON OVER, it will be easy to switch with the use of a nail on your finger. Once this is done, you will have access to the data on the flashjet card again. This is actually a safety feature that prevents you from accidently formatting the jetflash flash card. Thank you and have a great day.
Jan 21, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
DXG-565V Flash Media Camcorder: my DXG -565V Flash Media Camcorders sd slot wont e...
There is a spring that puts pressure on the SD card. It is most likely stuck.
You will need to fish around with a straightened paperclip, but be careful not to bend anything or the slot won't work properly any longer.
this has happened to me a few times and it's always the same fix...the spring is jammed and needs to be coerced back into place.
Hope this helps!
May 18, 2010 | DXG Technology DXG-565V Flash Media...
My wii fit board won't connect with tv is the blue light suppose to stay on all the time or flash
Hi, thanks for using Fixya!
  • Open the SD card slot on the nintendo wii, open the battery panel on the wii balance board.
  • Press the two red sync buttons on the wii console and the balance board and hold for 3 seconds.
  • The blue light on the back of the wii balance board should flash for 5-10 seconds and then stay blue.
  • If this doesn't work then try changing the batteries and trying again.
If it still isn't connecting then the problem is something a proper nintendo expert will have to help fix.
Thanks, I hope I have been of assistance.
Jan 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
How do i find the memory stick on the computer? i put it in the slot and the light came one but nothing happend...it is a Sony 4GB Memory Stick Pro Duo Memory Card
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Dec 25, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Not recognizing memory card in slot
are you sure you are sticking it in the correct slot for your memory card and you are not sticking it in backwards/ upside down
also this memory card works in your cammera still correct?
Mar 31, 2009 | HP DeskJet 5650 InkJet Printer
Pop up flash will not stay open when you push the release button.
The post that holds the spring commonly breaks off. The top has to be removed to replace it - a $60 repair by an independent repair shop. I wouldn't recommend removing the top yourself unless you know how to discharge the 300Volt capacitor.
Dec 03, 2008 | Pentax MZ-50 35mm SLR Camera
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
