Question about Hamilton Beach 22502 Digital 2-Slice Toaster
Toaster will only toast on one side
We have a 14 month old Kitchen Aid toaster. Yesterday it stopped working during use and I found that the breaker had tripped. I reset the outlet plug and it works now, but will only toast on the outside burner. Can it be fixed?
    President:
  • 2,976 Answers
You need a new heating element. Here's the link to kitchin Aid customer service. You will need the model & serial numbers to get the right part. Also, you will have to detail which element is out, such as looking at the handle it's the second from the left or whichever it is. Each one has a specific part number and they are not interchangeable.
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service-contact/
Posted on Feb 07, 2009
  • 537 Answers
Is there a cancel button for this? It might be stuck. Check this and let me know
Toaster CTZ2003.BK toasting on one side only, inner two elements only part glowing as i assume would be in bagel mode, is it worth repair , only 15 months old?
The warranty is only 6 months! This is the page for support and repair. Contact them and ask. In my experience, the elements for these type of toaster come as one block and are not easy to fit.
Warranty Information Delonghi Australia
Apr 13, 2017 | Kitchen Appliances - Others
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Toaster not toasting on one side
No doubt the element is out on that side . You may be better off just replacing it unless it has some sentimental value to it . Chances are the element won't be found since it is that old.
Jan 27, 2013 | Kitchen Appliances - Others
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Jun 07, 2010 | Dualit 31213 3Slice Toaster
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
My toaster only toasts on one side of the bread...can I replace the toasting elements? It's a Kitchen Aid brand.
The kitchen aid brand is usually a good one,
i prefer you too replace the toasting elements because in my brand i faced the same problem and i replaced the toasting element . it worked wonders for me
Dec 29, 2009 | Kitchen Appliances - Others
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Hamilton Beach 22502 Digital 2-Slice Toaster Logo
302 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
