Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Dell Dimension 3000 Power Problems
My Dell Dimension 3000 Pentium 4 Desktop is shutting on and off. Why! The green light comes on for a couple of seconds then turns amber then turns off. It happens fast enough for me not to see anything pop up on the screen. Help!
  • cmsa12fish Feb 07, 2009
    How could I check these possible problems out?
    President:
  • 1,902 Answers
You have one of two problems. Power supply bad or your heat sink has got to hot and has fried your processor
Posted on Feb 07, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 07, 2009
    Check the power supply by when you turn on the computer the fan on the power supply top back should run not matter what the computer does. To check the processor you need to get into the computer and you will see a big silver box that is your heat sink. See if you can small any type of electrical burning smell.
When i start up my dimension 3100 dell desktop instead of a green light i get a flashing amber light. people say it is the power supply but the light wouldnt even come on if it was. can you please help me?
No, the light WOULD come on if it was a Power Supply problem.
1) If ALL of the LED lights on your computer were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses from 51 to 125 Watts. Depends on what Processor it is.
Dell Dimension 3100 desktop computer?
An Intel Pentium 4.
Intel Pentium 4 model 640.
Can operate up to a frequency rate of 3.2GigaHertz. (3.2GHz)
Fits in a Socket 775 processor socket. (Also know as Socket T)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Can use up to 84 Watts.
You have enough power to light that LED light, but not enough power to turn the Processor on.
Dell Support > Dell Dimension 3100 > Service Manual > Advanced Troubleshooting > System Lights,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
"Power Light - Blinking yellow - A power supply or system board {Motherboard} failure has occurred"
Dell Dimension 3100 desktop computer Service Manual, (Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts > Power Supply
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 20, 2011 | Dell Dimension 3100 PC Desktop
Power source is ok so is the memory , is it the motherboard
That is usually caused by bad ram. Take the new ram out, put the old ram back in and see what happens.
Apr 11, 2009 | Dell Dimension 3000® Pentium® 4...
Dell dimension 3000 desk top, does not turn on ?
It's one of two problems: bad power supply, or bad motherboard. If you are electro-mech inclined, remove the power supply. Take it to your local computer repair shop, and ask for one just like that one.
Reinstall, power up should (most of the time) fix this problem. If still no power, you need a new mb. Return to the shop, ask them to replace mb. This repair should be right around $250.0 - tops. Any more than that - replace computer.
Hope this helps. Either way, if you wouldn't mind taking the time to rate my response, it would be much appreciated!
Thanx and good luck.
gurutim
Mar 22, 2009 | Dell Dimension 3000® Pentium® 4...
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Dell dimension 3000 won't turn on
have u checked with the cmos battery?
please replace the battey and check if it it working
if it doesnt turn on try to get *********** board repaired or replaced
Dec 03, 2008 | Dell Dimension 3000® Pentium® 4...
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension Shut Down
Hi
You query suggest you have Dell Dimension 3000. Dell Dimension 3000 is a desktop PC and does not have a battery backup by itself.
I am assuming the battery backup you are referring to is a UPS (Uninterruptible Power Supply). If this is correct then by your description of the issues, the UPS may be faulty (indicated by the Red light and beeping).
Disconnect the computer's power cord from the UPS and connect it to a wall power outlet to confirm or rule out the UPS as the offending device.
If this does not help reply with more info
Mike
Aug 15, 2008 | Dell Dimension 3000® Pentium® 4...
PC will not boot up
well when u upgraded did u format the hard drive u have to do that
Jan 20, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
131 people viewed this question
Alun Cox
