Question about Datalogic Falcon 4420 Handheld Barcode Scanner
Falcon 4420 Remote Networking error
You have been disconnected from the remote computer you dialed. Verify the Baud Rate and retry the connection.
This happens frequently when starting a scan or attempting to connect to the computer through a USB connection. I have checked all available connection settings as well as wifi with no effect. any help would be greatly appreciated.
2 Suggested Answers
  • 47 Answers
SOURCE: Can we upgrade our Falcon CE4.2 device to CE5.0 your rep. There is probably a cost to this. There is with every other manufacturer
Posted on Nov 04, 2009
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Feb 27, 2012 | OKI Office Equipment & Supplies
How to restart falcon 4420
Falcon 4410/4420(52 Key) - Press and hold the power button and insert a paper clip into the cold reset button below the Alt key
Jan 07, 2012 | Falcon 4420
When I try to connect to internet I get this message you have been diconnecter from the remote computer you dialed verify the baud rate setting and retry the connection. my baud rate on desktop is...
How are you trying to connect to the Internet? It sounds like you are using another computer as a gateway, so if the other computer is offline you will not be able to connect. If you have another way to connect (such as a satellite, DSL, or something else like them, you need to disable your current connection. Go to control panel, internet options, connections, and see how you connect. IF YOU DO CONNECT THROUGH ANOTHER COMPUTER DO NOT CHANGE YOUR CONNECTION. Otherwise, disable or delete that connection, and then go to the lan portion (towards the bottom of that menu) and click it. In the new menu, unclick automatically detect settings. If you are not sure what you are doing, write back and be more specific with your question.
Sep 22, 2010 | Sylvania G-Netbook
I have a 4420 falcon and it works only when the usb cable is connected to te computer in other words, the internet doesn't function when i disconnect it from the stand that has the cable connected to it....
I presume the PC you connect to has an internet connection. If so this is normal behaviour. When you connect to a PC via a USB cable and ActiveSync the connection is given an IP address via the host PC. If under the ActiveSync settings you are allowing the connected device to use the host PC's internet connection then the 4420 has access to the internet. simpuls.
To get a connection to the internet you would require a different connection, i.e. wireless.
You would also need a wireless access point or wireless router. Set the SSID and encryption on the wireless device and match it on the 4420.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
or TEL 01202 620955
Jan 17, 2010 | Falcon 4420
Oct 29, 2009 | Datalogic Falcon 4420 Handheld Barcode...
Need to know what bod rate is on my fax
older fax machines used a 9600bps baud rate, meaning a transfer rate of 9600 bits per second. a Bit being an 7th/8th of a byte. The newer machines can transfer at 14400bps, which older machines can not read, as its too fast. thats why they asking the BAUD rate.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
this sounds to be an issue with your software, it is not from any of the standard installed software, try and cold boot the unit and reinstall any required software
Jun 04, 2007 | Falcon 4420
Datalogic Falcon 4420 Handheld Barcode Scanner Logo
291 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
Level 1 Expert
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
