Question about Kenmore 24032\24036 Top Load Washer
Where is the clutch in the Kenmore 90 series?
Ok..so I'm a girl... : ) I fixed my dryer last month, so I figure I can fix my washer too! Kenmore series 90- service man came out and said I needed a new clutch for the machine- 247.00 please.
I called Sears, they have the part and it's only 47.00- Is this something I can fix, or do you think I need to give it up to the ghost?
I've been all over the web trying to see if there are posts on how to fix this. thanks..hope you can help!!
Vikki
  • vcarsontaylo Feb 07, 2009
    Thank you for your comments- now I'm a bit concerned since I had a repairman come out to tell me what was wrong- he stated it was the clutch...so, now what?
    Oh boy...a new washing machine...how depressing can that be in this economy..*sigh* -- still not sure what I will do.
    One more question...wouldn't the repair man need to take apart the machine to tell me what the problem was..?
    I wasn't home when he came out and my charming son told me he just tested the machine and fiddled a little bit...maybe the coupler instead of the clutch??
  • 360 Answers
It is not an easy repair. it will require a major dissemblance the washer. perhaps the best bet would be to apply the $247 repair cost to a new machine. The clutch/transmission is about as far into the machine as one can get. The parts are difficult to maneuver and are heavy.
Posted on Feb 07, 2009
  • Kenmore Master
  • 8,220 Answers
It probably ain't even the clutch. You must inspect the washer first. Here is some WISDOM
Additional sites of interests to your prob:
http://repair2000.com/coupling.html
http://appliancejunk.com/motorcoupler.pdf
Did this:
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
  • Dan Webster
    Dan Webster Feb 07, 2009
    That is right . The repair man ain't Houdini.
    You gotta look at it before you can make an assessment.
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 series washer will not dispense hot water
shut off the house vater valve,remove the hot water hose,stick it in the tub or bucket,turn the water on,if water comes out ok chnage out the water valve on the washer.
Feb 22, 2011 | Kenmore Washing Machines
I have a kenmore 90 series dryer model # 9659323 and when I push the start button there is just a click and it wont start. I am trying to find out information on how I can fix it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 03, 2010 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Electric Dryer won't start
Hi.Thanks for the question I would look to see if the belt is ok.Some dryers have a belt break switch, which is located by the motor.I would check the door switch.on the door try that thanks
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 24032\24036 Top Load Washer Logo
619 people viewed this question
Sal De
fordexpert
Robert Rankin
