FixYa.com
Tags:
Ace Hardware Hunter& Low Profile III Ceiling Fan
Hunter PGP Sprinkler Heads ?? (by 3 users)
By paulrmc - usenet poster
I had some Hunter PGP sprinkler heads installed several years ago by a
professonal irrigation company. At the time, they claimed that these heads
were of a "Professional" grade, and were not the same Hunter heads that
could be bought in a Home Depot, Ace Hardware, etc.
Does anyone know if Hunter makes a "professional" sprinkler head, that are
not sold in common stores like Home Depot, Ace Hardware, etc ???
Thanks for any comments !!
--James--
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 24, 2008
Can Hunter rotary sprinklers be rebuilt or repaired? Several heads refuse to arc as they did when first installed. I'm looking for a simple solution, a default setting perhaps, and set the arc again.
Can Hunter rotary heads be repaired? Units I have have stopped spraying in an arc and spray only to one spot, or in another case the head doesn't get quite back to the right stop and freezes.
Thanks
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Odud
Odud - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sorry, I should have been clearer.
Yes. Their commercial grade sprinklers are the I- series. You can
order the I-20 from HD online, but I don't think you will find them in
the retail stores.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
If I am not mistaken yes they do. The version sold at Home Depot is a
lighter or different version PGP than you would by at an irrigation
supplier. While the PGP is labeled as a light duty commercial and
residential type irrigation head it is very popular for its ease of
operation. However, there is also the l-10/i-20. It is similar to the
PGP but is more heavy duty and has a couple more bells and whistles
available as accessories.and is a bit more expensive.
Anyway, I am pretty sure that the PGP hunter Rotor head available at Home
Depot is NOT the same type you would be able to buy at an irrigation
supplier that wholesales to the irrigation contractor.
Solution #3
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
It is, but the info doesn't answer my question.
Thanks !!
--James--
Looks like it is an entry level rotary sprinkler.
Solution #4
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
ear+Drive&BV_SessionID1835964869.1127080937&BV_EngineID=ccddadd
fkdggfmgcgelceffdfgidgmj.0&MID=9876
Solution #5
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Yes, but did not answer my question.
--james--
A Pro installed them in my yard. They work damn good.
Solution #6
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
Can you Help with these Electric Fans problems?
Electric Fans
grinding of holmes hasf1516 fan
Hello, I have a holmes... Answer This...
Electric Fans
ceiling fan chain broke
hertiage hugger ceiling fan Answer This...
Electric Fans
fans spinning opposite...
Built a custom home and had two... Answer This...
Electric Fans
prostandard floor fan model...
need on off speed switch .can i... Answer This...
Ace Hardware Hunter& Low Profile III Ceiling...
Hunter PGP Sprinkler Problem
I have Hunter PGP Sprinklers... Answer This...
Repair Service
Find Electric Fan Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
