Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
No power out
Yamaha generator ef 1000is what will be the probleme looking for a shop book
  • Marcel Martel Feb 07, 2009
    with out a shop book how can i test the generaton ? please reply thank Marcel
    Sergeant:
    Champion:
  • 373 Answers
Try yamaha.com/shop book
Posted on Feb 07, 2009
Yamaha ef 1400 generator runs but not producing power
Check the brush holder for worn brushes. If they seem ok then the voltage regulator has failed.
Oct 31, 2017 | Yamaha Electrical Supplies
How do I replace broken starter rope
I cannot see it obviously. Clear the are from its cover and recoil another rope to the crank winding. Keep in mind to put the crank wheel under its spring tension before attaching the new rope.
Jul 02, 2015 | Yamaha EF1000iS Portable Inverter...
Yamaha EF 1200 has no spark Changed plug still no spark
I have a neighbot that seems to have this problem half the time he tries to start his. I turn the ignition switch on and then it works 'til next time. He drinks a little. You should also check the oil level as many of these have a low oil cutoff switch. If this all checks out, then it is most likely the ignition module.. Hope this helps,Robert
Mar 26, 2013 | Yamaha Electrical Supplies
Yamaha ef 2800 i generator no spark.Eliminated all control systems (disconected) checked coil showing 0.2 ohm across pos to neg terminal and 12.4 ohm from either pos or neg to the plug wire.any other ideas...
Check the low oil sending unit.(Make SURE there is enough oil in the unit) Take the 2 wires off and join together. If the unit starts, then replace the sending unit and put the 2 wires back on. good luck
Sep 20, 2010 | Yamaha 2500 Watt Industrial Inverter...
Can you help me? I have generator yamaha ef 2600. Generator normally running about 3 minutes then rpm comes unsteady and gen stops. Moreover at load 2kW gen immediatly works unsteady and stops. Without...
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
  1. If smoke comes out of muffler - the input air is not sufficient. Try to clean or change air filter (cleaner).
  2. If no smoke, the fuel is not enough. The reason may be the mechanical governor, or the fuel supply to it, fuel filter/strainer etc.
Aug 05, 2010 | Yamaha 2300 Watt Generator - EF2600
Yamaha ef 2400is starting
The manual contains a schematic which does not show a heat sensor. You need to narrow it down to a fuel or spark problem. The easiest to check is spark. If you do not have spark, it could be the plug, wire, oil level sensor, magneto, coil or TCI module. If you have spark, then it is likely a fuel problem. Open drain and see if fuel is getting to the bowl. If not, check tank, valve and lines. If yes, it must be the carburator. Good luck.
Jun 09, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
May 07, 2009 | Electrical Supplies
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
504 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
