Question about Sony Xplod XM-1652Z Car Audio Amplifier
What does it mean when the red light come on
I got a red light and then the amp cut off
  • 323 Answers
The amp is being over-loaded on the circuitry board.
You need to double-check what ohms the amplifier can handle.
Make sure the gain on your amp is not turned up too high.
Make sure you have a good ground.
Make sure the RCA cables are not shorting out.
Hope this helps.
Posted on Feb 07, 2009
When i play a bit loud (not too much though just when the light blinks red on the hard play) the sirquit closes the amp for two seconds.can you healp me on this ?thank you very much
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
Feb 08, 2011 | Ibanez P500H Promethean Bass Amplifier...
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
Jul 06, 2010 | Fellowes PS60-2 Shredder
Xbox 360, when i turn it on 1 red light comes on, then when fan kicks in 2 red lights come on & it just cuts off
DO NOT OPEN THE CONSOLE!!!!!!!! Microsoft will fix it for free!
Alright, the one red light means it has a "Hardware Failure".
Since its 1 Red light it is known as the "e74 Error" Which lucky for you Microsoft will fix for free.
The 2 Red lights mean Your Xbox 360 is overheating.
Microsoft will fix it for free with free shipping. Takes about 2 weeks.
There is videos and different ways to fix it online but it will happen again with those half baked solutions and also with this Microsoft adds alot more time to your warranty.
Please go here to Send in your xbox
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
May 09, 2010 | Microsoft Xbox Console
My playstation3 just cut off in middle of game, red
Thats the red light of death.
Visit this website if you want information on how to fix it.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
The adapter light is just yellow & everytime i cut on the 360 the 360 goes off & the adapter light turns red.
Hi There
ITs the three red dots of death , what i mean is they had that all over and had millions of people had to recall them, i guess your just getting crapy xbox's my friends xbox did that, he took to a shop to get it fixed, but they couldnt, so i guess your sol, get xbox 360 elite they hardly had any problems with those.
Accepte My Greetings
Oct 09, 2009 | Microsoft Wireless Network Adapter Xbox...
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Sony Xplod Amp
well you might want to try using 30 amp atc fuses instead of 10 amp fuses on your amp, because you are getting an overcurrent from your alternator then from your battery. I have the same amp and you will find that your subbs will hit better too. also check on your ground wire from your amp as this also will cause the RED light to come on. :)
Mar 24, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
When the red protection light comes on wat does that mean?? amp plays for 5 secs and tha stop while red is on, and my cars dome light dims at the same time
If the red light is coming on It mean their is a grounding problem. Also check if the power and ground wire is not cut or broken.
Feb 28, 2009 | Sony XM-1252GTR Car Audio Amplifier
Power light
This could be a DC offset condition. Check you manual for what this means. Or other condition. First Disconnect the Subs and try it. If it still goes red then disconnect the RCA's and try it again. If the Led continues to go red after the click then the Amp is hosed. The Click you hear is an internal relay that cuts the subs in after a dely so you do not get the turn on THUMP of the radio at your subs.
Jul 08, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Sony Xplod XM-1652Z Car Audio Amplifier Logo
88 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
