Question about HP LaserJet 2100 Printer
HP 2100 LaserJet, was functioning ok, now won't power up, power to AC plug is ok ... Is there a fuse somewhere ? Jim
  • k1vjd Feb 07, 2009
    leroyal,
    tnx for the input, it turned out to be an intermittent power
    switch on the side of the unit ... came back to life after I rocked it
    back and forth ....
    Tnx/Brgds
    Jim
    MREO/ SS Cape Jacob
    Genius:
  • 2,120 Answers
Remove rear cover and fuser.
Blown fuses usually point to a bad power supply which is the circuit board under the fuser.
Posted on Feb 07, 2009
How do I download driver for HP 2100 Laserjet
  1. download the most recent version of the PCL 6 driver.
  2. Under the Quick jump to heading click the desired version of Windows Printer Driver.
  3. Select the PCL 6 drive.
  4. Select Save this program to disk and click OK .
  5. Under Save this program to disk choose a location to save the file, note the location, and then click Save .
  6. When the download is complete, the file will appear in the directory specified in the previous step.
To open the file double-click the file, click OK , and then click Unzip . After the file has completed self-extraction, click OK then click Close . follow this instructions
HP Laserjet 2100 Printer Driver Free Download For Windows
Apr 26, 2014 | HP LaserJet 2100 Printer
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Laserjet 2100 prints code
Install the HP LJ III driver and this should work as advertised.
May 22, 2009 | HP LaserJet 2100 Printer
HP laserjet 2100 will not print PDF from Adobe Reader 9.0 correct
to print to pdf use software printers one can be found here
Dec 26, 2008 | HP LaserJet 2100 Printer
Laserjet 2100 Won't turn on!
Yep, the power cable can be faulty, test a different one on a different socket. Try also playing with the power connector on the printer.
If the power cable is fused, like for example in UK, then check the fuse.
If it still does not give any sign of life, then there is a fault on the power supply board, inside the printer, usually the power supply fuse. Part is about $45 refurbished/$55 original .
If the problem is not the fuse you will need to get a technician testing on board component, and probably replacing a faulty resistor or capacitor.
Sep 26, 2008 | HP LaserJet 2100 Printer
Print problem
How old is your toner cart?
Have you given the toner a little shake lately?
Is there paper wrapped around the fuser causing only a partial printout?
Jun 26, 2008 | HP LaserJet 2100 Printer
Need A Manual
HP has a pdf manual online for your model.
Here is the URL link for the HP LaserJet 2100.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=25469
Nov 28, 2007 | HP LaserJet 2100 Printer
HP LaserJet 2100 Printer Logo
279 people viewed this question
Ben Johnson
