Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Belkin 8233 - no routing between hardwire and wireless...
I've connected the notebooks (wirelessly), access to internet - all ok
I've connected my NAS on the hardwired LAN port 1
None of the notebooks see the NAS box.
I've replaced a Linksys with this Belkin....... same configuration works perfect on the Linksys, but not on the Belkin.
Is there a solution or I am sitting on a defective Belkin?
  • Anonymous Mar 07, 2009
    Please describe the specifics of your problem below. We'll add your post as a comment to otct's "Belkin 8233 - no routing between hardwire and wireless..." problem, and notify you when a new solution is offered.
  • 928 Answers
Try to see if file sharing between computers connected to the Belkin is working. If it does not try to update the firmware of the belkin. If it does not work its switching function si defective.
Posted on Feb 07, 2009
  • Thomas Lim
    Thomas Lim Feb 07, 2009
    Try to use file sharing between your computers on the belkin. If it does not work then your belkin is defective. Normally problems like this arise if the switching function of the router does not work. The routing works but not the switching. Try also to update the firmware of the belkin
Wireless no longer accesses router
OK try this go to that PC, go START>>RUN>>service.msc (enter) Now when services window comes up, scroll down to DHCP, set to OFF & Disable, reboot, now try again. Sometimes just a Turn it ALL OFF, and ON again and most often it will sort itself out., IF it was working OK prior. You could always run the "Connect to internet Wizard" again, and do that. Also go into router and ensure that DHCP, is set to ON in the Router. Sometimes, a simple re-setup will get it all working again too.
Apr 01, 2010 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Router hooked to modum no wireless light can access internet from cable but not as a wireless system Belkins F5D-8233-4v3
You can switch wireless on/off
Download the manual from here
starting at page 42
check out page 43
and see what the setting is on your router
Aug 07, 2009 | Belkin Computers & Internet
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Jun 22, 2009 | Toshiba Satellite Pro A200-EZ2204X...
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in on your browser tab or typing i in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Feb 26, 2009 | Belkin (F5D72304F5D7000) Router
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
this is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Feb 03, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
My Belkin N1 and my xbox 360
I just got it and yes latest firmware as of end of mai has been downloaded
Jun 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address:
Subnet Mask:
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
180 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
