I would like to hook up my Pioneer KEH-M5550 tape /CD to my computer and need to know the wiring colours from tape output heads to the amp ?
  • ricardoandma Feb 07, 2009
    I have tried the cassette thing and the sound is very poor quality though >Appreciate the comments about the amp being overdriven
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I am assuming that you would want the sound output of a laptop to feed the Pioneer KEH-M5550. If you would hard wire the output of the laptop to the input stage of the amp where the tapehead goes into, the amp would be overdriven. This is because the output of the tapehead are very very low while that of the the laptop is high line level (enough to drive even a headset). What could be suggested is to use a Car Cassette Adapter similar to shown below available from most electronics stores such as here.
Alternately, if the KEH-M5550 has an AUX INPUT RCA to RCA (meant for MP3 players), then that may be used.
Good luck and thank you for using FixYa.
Posted on Feb 07, 2009
  • Louie  Role
    Louie Role Feb 07, 2009
    I do agree on the poo sound quality of the cassette adapter; and technically, it would be rather difficult modding the circuitry of the Pioneer to accommodate a line in since a logic circuitry is used for signal source selection, volume & tone controls.
    A better option would be to use an FM modulator (stereo transmitter) where the laptop would broadcast its sound output to an unused FM frequency and the KEH-M5550 would pick it up as a regular stereo broadcast. Sound quality wise, it is very good to the point some trunk CD changer system uses this method. Below is a very good example while other versions/models may be viewed here.
    Cheers.
Keh pioneer will not illuminate
I am assuming you are talking about the tape deck (head unit) and not the changer. You more than likely have burned out bulbs in the face. Unless you are good at desoldering and soldering, I would suggest you have them replaced professionally.
Feb 23, 2012 | Pioneer KEH-P4400 CD Changer
Looking to find wiring diagram for a keh-1400 from pioneer ,car radio
red is 12 volts from ignition
yellow is constant power from battery
black is ground wire
white +
white black - front left speakers
gray +
gray black - right front
green +
green black - left rear
purple +
purple black - right rear
blue or blue white remote antenna or amp turn on
this all you need to install your radio
any more questions go to http://www.tintingbyfredjohnson.com and email me
Dec 22, 2010 | Pioneer KEH-1400 CD Changer
I have a pioneer cassette tape model# keh-1750,but i don't know its wiring,about to connect with car power supply.plz give me a suggestion, how i connect tape with car.
COLOR FUNCTION
RED ACCESSORY
YELLOW BATTETRY
BLACK GROUND
BLUE POWER ANTENNA
BLUE/WHITE AMPLIFIER TURN ON
ORANGE ILLUMINATION
ORANGE/WHITE DIMMER
GRAY RIGHT FRONT +
GRAY/BLACK RIGHT FRONT -
WHITE LEFT FRONT +
WHITE/BLACK LEFT FRONT -
VIOLET RIGHT REAR +
VIOLET/BLACK RIGHT REAR -
GREEN LEFT REAR +
GREEN/BLACK LEFt
Dec 18, 2009 | Pioneer KEH-P1010 Cassette Player
How to conect a cd player to 4 chanel amp in my car (ampjensen x
all you have to do is run the audio cables(red&white) from the output on cd player to input on amp and then hook up the remote wire from stereo(should be blue wire) and run that to amp...then all you need is a power wire and ground wire for amp!!
Jun 04, 2009 | Pioneer KEH-P4020 Cassette Player
I have a used pioneer cd deck. No sound to speakers
The blue wire would be your remote wire to hook up a amp and if you have a wire harness all you have to do is match the colors up.
May 14, 2009 | Pioneer DEH-P3100 CD Player
Soundstream300 amp how do I hook it up to my pioneer head unit
That depends on which wires you are referring to. High level inputs or low level (RCA) outputs? If you are thinking about trying to wire the amp up to your Pioneer direct, ie; running the power and ground off of the factory harness, think again, you'll fry your electrical system. You need to run a seperate power kit (8 gauge minimum; 4 gauge pref), then run RCA's from the line level outputs on the Pioneer. If you are planning to run a sub with the Soundstream then run your RCA's from the Pioneer's sub output. Let me know if I can help you any further.
Aug 17, 2008 | Soundstream EGA900D Car Audio Amplifier
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
42 people viewed this question
 Grubhead
Grubhead
