Hondahttps://cdn.powerequipment.honda.com > manuals
PDF
This owner's manual is considered a permanent part of the generator and should remain with the generator if resold. The information and specifications included ...
PDF
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Hond... associated with operating your NAC portable generator, following the precautions listed below will assist you in .... For detailed engine information, refer to the Honda Engine Shop Manual. Note: ? ..... (e) Do NOT remove the diodes or de-solder the wires attached to the diodes. (f) Ensure you have ... NDK-4100YE. WIRING ...
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
Honda GX400 either a motor car (which will have a '12V Generator' on board..) or a largish sized Honda utility engine for water pumps, fans and electricity generation of of over 5KW (5KVA)
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
YOU CAN MAKE A SPARK TESTER BY TAKING A SCREW DRIVER AND PUTTING INTO THE WIRE AND BY BEARLY TOUCHING THE BLOCK TO SEE IF A SPARK COMES BETWEEN THE BLOCK YOU WILL SEE A SPARK IF THE COIL IS GOOD
