Question about Maytag Neptune MAH5500B Front Load Washer
Won't Spin I have a maytag Neptune MAH 5500BWW - It will go completely through the entire cycle but won't spin. The only water left is the water in the clothes so it is draining properly. I had a repair guy come out and take a look - it worked just fine while he was here. He did check a few of the connections and it appears there may be a loose sensor for the latch assembly and he thinks it could be the cause and assumes it will eventually break. Does this seem logical and can I fix it myself? He said the whole assembly has to be replaced because the "box" has plastic welds at the bottom which prevent the ability to simply replace the latch sensor. If it's easy enough to fix what part should I order? Thanks.
  • lvkidds Feb 08, 2009
    Maytag.com does not offer the manual for this particular model.
  • KENNETHEVANL Mar 19, 2009
    HOW CAN I STRAIGHT WIRE THE DOOR SWITCH MAH5500B WASHER THANKS
    Scholar:
  • 99 Answers
This is joyce
Go to Maytag.com and put in your model # and download manuel and this will show you every part on your machine, then you can see if you can fix it or not, or just simply straight wire it. which is what a lot of people have done, I dont know if yours can be done this way. this is a rather newer unit. the assembly is not that exspensive if you do it yourself probl less than $100.00
hope this works
Joyce
Posted on Feb 07, 2009
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag washing machine MAH 5500BWW makes a noise like a freight train in the spin cycle. What should I do?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 20, 2011 | Kitchen Ranges
Maytag washer MAH 5500bww seems to run OK, but it does not pump out all the water(pumps out some) at the end of the cycles, churns remaining water during spin
Open the rear panel and remove the drain pump and clean it.
If there is nothing in the pump, check the drain motor for 18 ohms with a volt/ohm meter.
Not 18 ohms, replace the motor.
May 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
