Question about Whirlpool Dryers
Dryer belt install
I bought the belt, got the front off the machine, but I can't figure out how the belt can go under the half-round end of the idler pulley. The belt is a closed loop, and the idler pulley fixture is closed at the end. I've got to be missing something.
    President:
  • 2,992 Answers
This site has a good illustrated procedure for replacing the belt. The picture in step 11 shows how to route the belt under the idler pulley.
http://repair2000.com/wpoolbelt.htm#INSTALLING
Posted on Feb 07, 2009
How do you replace the belt on a whilpool dryer , is there a video available
1) remove filter
2) remove 2 screw from top of filter housing
3) pop the top
4) remove front panel
5) remove drum and clean the dryer
6) oil the rollers
7) oil the idler
8) place drum back with belt
9) Insert idler in floor
10) install the belt by passing it through the idler and looping it onto the motor. Turn the drum a few rounds to make sure the belt is not twisted then re install the front.
Here is me in my movie I made that shows how:
Oct 12, 2012 | Whirlpool Inglis IP8200 Dryer
My nephew took my dryer apart to replace the belt and cannot figure out how to re-attach the idler on the Whirlpool LER5620KQ1 model. Is there a manual available that shows exactly how to do this?
If the model number you listed this question under is correct, changing the drive belt and reinstalling the tensioner involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt has broken, this may sometimes cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
For future reference, the part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
NOTE: If you still have the Teflon glide type tensioner (does not have a wheel), Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Oct 18, 2010 | Whirlpool LER5636P Electric Dryer
Do I have the idler pulley installed incorrectly? I can't seem to get the belt back on and the idler pulley rests on the motor pulley.
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Dryers
Whirlpool LG5531xkwo need to replace drive belt and re-install idler pulley. I have found a parts listing schematic, but it's not clear how the idler pulley should be re-installed in relation to the belt...
Replacing the dryer belt and installing the tensioner on this model dryer involves the following steps:
2. Remove the lower toe panel by inserting a putty knife along the top seam about 2 inches in on each side. This will depress the retaining clip that holds the panel in place and the panel will open.
3. Remove the two screws that were under the lint screen and lift the top panel.
4. Unplug the door switch conector plug and any ground wire that may be installed on the front panel.
5. Locate the screws that hold the front panel in place. There should be one screw on each side in the cabinet interior and two on the lower panel in the front.
6. With the door shut, lean against the front panel and remove the screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the bottom edge of the front panel with the holes on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
If you still have questions, please let me know. I hope this helps you
Nov 12, 2009 | Washing Machines
We need to replace the belt . It is broken and we are not sure exactly where it goes or if we have to take the dryer apart. Model number yleq5000kq1
The belt wraps around the dryer drum and connects to a pulley on the drive motor. It is held tightly in place by a belt tensioner.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
If you still have questions, please let me know. I hope this helps you.
Oct 14, 2009 | Dryers
I am installing a new belt but the pulley that mounts to the ground i found was not attached and i am not posotive of its correct spot i need a diagram
The idler pulley goes in front of motor shaft. There is two slits in sheet metal where it slides in. after pulley is on. put the belt around drum and pinch belt together. put belt under idler wheel then put end on motor shaft. You can push up on idler pulley to get around motor.Make sure grooved side of belt is wrapped around drum. Good Luck!!
Apr 24, 2009 | Dryers
We are trying to install a dryer belt onto a GE older moder dryer and can't figure it out. The model no is GDX8060RT429
Hi. thanks for the question. remove the top. lift , remove front. slide belt on drum .clean all lint. reinstall front and top. pull away from wall. remove back panel. motor on right idler pulley on left bring the belt down to push idler down ,to give the belt tension .put belt around motor pulley . thanks the appliance doc
Oct 02, 2008 | Dryers
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Belt Re-assembly
If you have a really old dryer (not a neptune), and if the idler pulley is about 4-in diameter you have chosen the hardest dryer to replace a belt on. There is a diagram on the bag your new belt came in. The door in the back of the dryer will be helpful. The tricky part about this one is that the fabric side of the belt goes against the basket drum.
A Neptune belt is easier, but can still be tricky.
First, put the drum in position against the back wall; but without the front supporting ring. The rubber side goes aginst the drum. Line up the new belt on the drum according to the marks left by the old belt.
Reach under the drum and match up the belt to its position on the motor pulley. Lift the idler pulley up until you can slide the belt onto it. Gently release the belt and idler pulley. Check to see if it stayed in position.
Carefully replace the support ring and install the four screws holding it in position. Slowly rotate the drum counter-clockwise about two full turns to better align the belt on the drum before restarting the machine.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Roper electric dryer
this should help couldnt find an actual picture so i took the time to draw a simple on in paint for you
Sep 27, 2007 | Roper REX4634KQ Electric Dryer
Dryers Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
