Question about LG WM1814CW Front Load Washer
I have an LG WM1814CW not getting .
Hi
My LG is not getting any cold water. The hot works OK. I have taken the top off and have switch the hot solinode leed to the cold solinode and it works. Any ideas. My guess is it the PCB.
Thanks
  • LG Master
  • 5,568 Answers
Did you check the simple things first?
Often, one of (up to) three screens are in line with both water feeds; one at each end of the connecting hose, still another at the input to the control valve.
Posted on Feb 07, 2009
Unit will not switch from hot to cold
check hoses connections- hot to hot and cold to cold at both ends. If not ok, check if you are setting the machine correctly. These days washing in cold water is effective.
Dec 08, 2013 | LG WM2101H Front Load Washer
Filter clean for water in
If you remove your water inlet hoses you will see a screen inset in the hot and cold inlet to your water valve. http://www.on-timeappliance.com/washingmachinerepair.html
Mar 27, 2012 | LG WM1814CW Front Load Washer
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
HOW DO i GET MY WHITES WHITER?
Use an oxygen-based bleach first--if not much better, try a chlorine-based bleach. Hot water works better than cold water. Try using a different detergent as well. Do these things one at a time to find which produces superior results. Hope this helps!
May 13, 2010 | LG WM1814CW Front Load Washer
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
At first we did not see any filters in the water hoses ... but after pulling the machine away from the wall we did find one - and it was clogged shut. So removing the material DID fix the cold water supply problem.
Thank you.
Feb 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I purchased a front loader washer and I only have a cold water line no hot,I hooked it up and the machine comes on but no water comes in the machine....can someone please help me figure this out??????
ok no problem where going to try this but your going to have trouble in the end...since you only have a cold tap ,,use a y hose to booth vavle dont cap of the hot,,,now you purchase a unit that has atc,,automatic temperature control..meaning the unit control how hot or cold the water will be in degrees,,,when you start the unit it puts hot in at the start even in a cold wash to break down the soap in the dispencer,,it doent know if you use powder or liquid,,so it just shots hot water though for a few second,,now that comes back to the begging,,if you put clothes like whites and that atc does nt sense that hot water the unit will stop until it do,,and you will get a code,,im here onthejob
Jan 02, 2009 | LG WM1814CW Front Load Washer
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem LG washer # wm1814cw overfills
You have a stuck cold water solenoid valve.
Try openning the machine and tap on the cold solenoid valve.
If this dowes not work, you may have to replace the valve.
Mar 25, 2008 | LG WM1814CW Front Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
LG WM1814CW Front Load Washer Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
